File Parsing
Set mode to : SP [SC983x] eMMC [Generic Android 7.x]
Loading : INTEX_AQUA_STYLE_3_V11_INDIANIntex_Aqua_Style_3_L1 5C_I_M00_S11E_170830).pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC9832
PacVersion : Intex_Aqua_Style_3_L15C_I_M00_S11E_170830
FastCheck : 0x00D9A15069
Loading files ...
File : fdl2.bin
File : fdl1.bin
File : system.img
File : sysinfo.img
File : cache.img
File : sprd_480p.bmp
File : ltenvitem.bin
File : userdata.img
File : pmsys.bin
File : ltedsp.bin
File : vmm.bin
File : ltewarm.bin
File : wcnmodem.bin
File : recovery.img
File : boot.img
File : tos.bin
File : u-boot.bin
File : ltemodem.bin
File : persist.img
File : u-boot-spl-16k.bin
File : prodnv.img
File : ltegdsp.bin
File : wcnfdl.bin
File : SC9832.xml
Load Ok!
Flashing Log
Start at : [12-12-2017 / 09:46:08]
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : INTEX_AQUA_STYLE_3_V11_INDIANIntex_Aqua_Style_3_L1 5C_I_M00_S11E_170830).pac
PacCPUinfo : SC9832
File : fdl2.bin
File : fdl1.bin
File : system.img
File : sysinfo.img
File : cache.img
File : userdata.img
File : pmsys.bin
File : ltedsp.bin
File : vmm.bin
File : ltewarm.bin
File : wcnmodem.bin
File : recovery.img
File : boot.img
File : tos.bin
File : u-boot.bin
File : ltemodem.bin
File : persist.img
File : prodnv.img
File : ltegdsp.bin
File : wcnfdl.bin
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 59 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
PickUp loaders from pac
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Reconnect Power/Cable!
Finish at : [12-12-2017 / 09:48:20]
Reset Via SVC
Start at : [12-12-2017 / 09:43:38]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 59 ]
Port Opened
Sync...
Read NV Also Fail On Picking Up Loader From .Pac After Loader Send 100% GUI Hang But Without Loading Pac. Read NV Done.
Operation : Read NV [ v1.27 ]
3. Insert cable
Phone found! [ 59 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC983x eMMC Loader v5.0 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Detected eMMC Flash , Structure detect Ok!
Read LTEx NV #1
Read Ok , 0x0006
Saved to : C:\Users\HG Solutions\Desktop\Intex Aqua Style 3\CX77xx_SPDNV.spdnv
Format With Loading .Pac Same Hang On Pick Loader From .Pac 100% But Without Load .Pac Format Start But Fail
Start at : [12-12-2017 / 09:54:37]
3. Insert cable
Phone found! [ 59 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Error!
ERROR : PART_FORMAT failed!
IC Test
Start at : [12-12-2017 / 09:59:02]
Operation : FlashIC ReadOnly/BadBlock Test [ v1.27 ]
3. Insert cable
Phone found! [ 59 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Prepare test data ...
Test flow #0 ...
Error on Flow Init! Battery/Connection problem?
Test NOT PASSED! FlashIc is DAMAGED/BAD!
Elapsed: 00:00:49
Finish at : [12-12-2017 / 09:59:52]
In Flash Tool Repartation Fail Or Partation Not Found Or Invalid Issue (Seems Emmc In RO State).
