11-22-2008, 09:02 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan (Layyah) Punjab Age: 37
Member: 453862 Status: Offline Thanks Meter: 53 | Huawei Ufone T156 Unlock Done simply use pana 01 v.1.56 and press unlock logs are here COM7 [VCP0] selected module v1.56 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Documents and Settings\Administrator\Desktop\New Folder\Huawei-T156_eeprom-sta_20081121-235557.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Documents and Settings\Administrator\Desktop\New Folder\Huawei-T156_eeprom-sec_20081121-235604.B1E.bin reading eeprom-complete... file saved: C:\Documents and Settings\Administrator\Desktop\New Folder\Huawei-T156_eeprom-complete_20081121-235610.B1E.bin reading additional data... done backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 33 sec Remove/Install battery now ! |
The Following 7 Users Say Thank You to Tahir Riaz For This Useful Post: |
11-22-2008, 09:50 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | download it from here. http://rapidshare.com/files/16620539...v1.56.rar.html |
The Following 3 Users Say Thank You to Umair Rashid For This Useful Post: |
11-22-2008, 10:18 | #5 (permalink) |
No Life Poster Join Date: May 2008 Location: City Center
Member: 770272 Status: Offline Sonork: 100.1603193 Thanks Meter: 227 | COM7 [VCP1] selected module v1.56 Device: Avvio-103A Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Avvio-103A_eeprom-sta_20081122-141726.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Avvio-103A_eeprom-sec_20081122-141729.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Avvio-103A_eeprom-complete_20081122-141737.B1E.bin reading additional data... done backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 46 sec Remove/Install battery now ! thanks infinty team |
The Following 2 Users Say Thank You to mobile_sos For This Useful Post: |
11-22-2008, 12:21 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Tahir Riaz @mobile_sos Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
12-16-2008, 21:51 | #7 (permalink) | |
Freak Poster Join Date: Aug 2003
Member: 37362 Status: Offline Thanks Meter: 25 | Hello, and congratultions, but plz tell which cable u used . txxxx Quote:
12-16-2008, 21:53 | #8 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
12-29-2008, 11:08 | #11 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Ufone Huawei T-156 unlock successfull Ufone Huswei T156 unlock successfull with simple LG-c 2500 cable. after unlock when i dial number message appear ::: facility not subcribed :::, finaly do full factory settings. all ok................... COM7 [VCP0] selected module v1.56 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sta_20081229-150020.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sec_20081229-150026.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20081229-150033.B1E.bin reading additional data... done backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 44 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to khadim100 For This Useful Post: |
10-11-2009, 14:01 | #14 (permalink) | |
Product Supporter Join Date: Nov 2008 Location: UnlockBank World
Member: 912688 Status: Offline Sonork: 100.1623116 Thanks Meter: 184 | Quote:
10-11-2009, 14:03 | #15 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jun 2009 Location: PAKISTAN/UAE
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | Quote:
Huawei UFONE T156 AY Z New Security Or New Film | maplegsm | FuriousGold | 12 | 01-05-2010 19:07 |
New Ufone T156 Unlock Done | ZubairArain | Infinity-Box | 5 | 12-14-2009 07:13 |
huawei new t156 unlock done | naveedbutt | Trash | 0 | 12-12-2009 07:48 |
Huawei T156 Unlock Done | ..::Waqar::.. | Infinity-Box | 1 | 02-17-2009 22:11 |
Huawei-T156 unlock done | saqibmalik | Infinity-Box | 3 | 01-27-2009 06:42 |
