10-03-2007, 00:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: uk
Member: 240930 Status: Offline Thanks Meter: 16 | N95 2sim dead after flash!! the program show error when write rpl(eeprom not found) which epprom file into site support i can download ? COM19 [Serial2] selected Device: Autodetect 6205-6227,6228 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization skip: Language Pack write: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom]... file saved: backup_eeprom_20071003-022152.B0E.bin flash: EC257E25082501:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware Area: Eeprom flash: EC257E25082501:29EA0000000000 Write: Eeprom formatting... flash: EC257E25082501:29EA0000000000 structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished device-id: 5300997C protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 warning: invalid identification, ask/rpl calculation reqired Probably identification data damaged, device id: 5300997C firmware version: N618_PCB01_GPRS_MT6227_S01.BIN_C3A0516F RPL file must be in folder: G:\Program Files\InfinityBox\ChineseMiracle\ You can create RPL from ASK via client/server right now and press YES. Do you want to write RPL file now ? error: no any expected answer error: no any expected answer: wrong answer after chip id request error: wrong answer[C4] error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request error: can't detect chip at required chip base error: rpl write failed Write Done Finished, time used: 486 sec Remove/Install battery now ! when i use read detailed information Ask/rpl view this error: COM19 [Serial2] selected Device: Autodetect 6205-6227,6228 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished device-id: 5300997C protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 warning: invalid identification, ask/rpl calculation reqired Probably identification data damaged, device id: 5300997C firmware version: N618_PCB01_GPRS_MT6227_S01.BIN_C3A0516F RPL file must be in folder: G:\Program Files\InfinityBox\ChineseMiracle\ You can create RPL from ASK via client/server right now and press YES. Do you want to write RPL file now ? error: wrong answer[3B] error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request error: can't detect chip at required chip base error: rpl write failed detecting eeprom area in 1 chip(s)... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: wrong answer[C4] error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request Can't detect eeprom area Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detection phase #3... error: unexpected termination/freez: 00000000 done detecting structure pass 1... error: unexpected termination/freez: 00000000 can't detect fat name location eeprom element #1 detection failed error: autodetection failed Finished, time used: 112 sec Remove/Install battery now ! what is problem?please help me |
10-04-2007, 00:34 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Change your cable, don't use Prolific based USB->RS232 converter but use cable based on FTDI chip (f.e. Infinity-Box or any other unibox). Also in case of any communication errors use 115200 instead of 921600 |
10-04-2007, 00:52 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
n95 8gb dead after flash | gorgans | Infinity-Box | 4 | 08-04-2009 16:06 |
N95 Clone dead after flash and Not detected by PC | tj_style | Chinese Models & Cloned Phones | 4 | 04-29-2009 12:23 |
n82 2sim dead after flashing with file from support | patric | Infinity-Box | 3 | 04-17-2008 20:08 |
n95 proplem dead after flash | moustafatch | Infinity-Box | 28 | 12-01-2007 22:39 |
