06-23-2015, 14:31 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Where the backup file located in Cm2mtk? But when on format, software backup done. Can i use that file to retrieve fone? where it located, or how to flash that file to phone? now the phone shows only XOLO and Tool DL image fail. Code: Start at : [6/23/2015 / 6:35:53 PM] Operation : Format FileSystem [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034473930515C8742EE71A5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 110100303034473930515C8742EE71A5 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : not found, will read now ... Format : Cache Only Format CACHE block Format block Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! Finish at : [6/23/2015 / 6:36:31 PM] Start at : [6/23/2015 / 6:36:52 PM] Operation : Format FileSystem [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034473930515C8742EE71A5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 110100303034473930515C8742EE71A5 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Already exist FMT Mode set to : 3 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! Finish at : [6/23/2015 / 6:37:26 PM] Start at : [6/23/2015 / 6:37:58 PM] Operation : Fix DL Errors [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034473930515C8742EE71A5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [6/23/2015 / 6:38:09 PM] |
06-23-2015, 14:48 | #3 (permalink) | |
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Quote:
Thank you. Its Done! Beginner With your tool | |
06-23-2015, 15:52 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Will add that automatically to "Format FS" , "Reset Privacy" operations in next version to avoid such things. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
