11-10-2011, 02:52 | #1 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1678589 Status: Offline Thanks Meter: 2 | While other tools CAN'T do INFINITY CAN Other tools can't support this phone but infinity FULL SUPPORT this phone Phone Cross CB95AT Code: Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6253 Ver: 8A04 SW:8A00 Initialize Boot6 ... Flash Inf not found, the Phone maybe bad Circuit maybe bad Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6253 Ver: 8A04 SW:8A00 Initialize Boot7 ... Flash Inf not found, the Phone maybe bad Circuit maybe bad Code: ==== [10/11/2011 8:01:54] ==== COM1 [VCP1] selected module v4.06 Device: _Autodetect MT6253 NOR Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A04:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6253:8A04:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: U11V01B50 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12 project-id: U11V01B50, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.06, database date: 07.11.2011): UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\Firmware\HP Cina\Infinity\Cross\CB95AT\UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12__fullflash_20111110-081028.B0M.bin Disconnect... done Finished, time used: 9 min 16 sec Remove/Install battery now ! ==== [10/11/2011 8:11:14] ==== COM1 [VCP1] selected module v4.06 Device: _Autodetect MT6253 NOR Checking data, wait... Action: read ffs/eeprom NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A04:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6253:8A04:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: U11V01B50 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12 project-id: U11V01B50, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.06, database date: 07.11.2011): UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 2Mb number of areas/bytes to read: 1:00200000 reading (HW_STORAGE_NOR)... file saved: C:\Firmware\HP Cina\Infinity\Cross\CB95AT\UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12__ffs_20111110-081310.B0M.bin Disconnect... done Finished, time used: 2 min 12 sec Remove/Install battery now ! Loading file v.02... UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12__fullflash_20111110-081028.B0M.bin loaded usb bootloader (file) is present: 00020000 rom info relocation detected rom info ver: 07 sw version: UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12 project-id: U11V01B50, 00000000 code offset: 00020000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2011-08-03 15-26 hw1: UNISCOPE53_BU1_10A_HW ==== [10/11/2011 8:29:12] ==== COM1 [VCP1] selected module v4.06 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12__fullflash_20111110-081028.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A04:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6253:8A04:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: U11V01B50 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12 project-id: U11V01B50, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.06, database date: 07.11.2011): UNISCOPE53_BU1_10A_PCB01_GPRS_MT6253_S00.U11V01B50.BIN_FLNK5N2866ATE_BQ12 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 8 min 22 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to bujokhp2 For This Useful Post: |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
