03-29-2009, 02:34 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Hungary
Member: 829361 Status: Offline Thanks Meter: 107 | White screen after flashing COM14 [VCP1] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:B203:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.79, database date: unknown): E806_PH1_EVCOM_MT6225S00.01_1_20090116.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: E806_PH1_EVCOM_MT6225S00.01_1_20090116.BIN ver. sw 2: E806_PH1.01.1, 00000000 ffs offset/size: 01C00000/00400000 detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 98000300000000:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 637 sec Remove/Install battery now ! The flash file can be downloaded from here: http://rapidshare.com/files/21476568..._.B0M.bin.html |
03-29-2009, 19:55 | #3 (permalink) |
Member: 829361 Status: Offline Thanks Meter: 107 | Thank you, but I know the features of CM after flashing more than a thousand chinese phones. This is a compatibility problem caused by a new flash chip. Other tools absolutely can not handle the flash chip of these phones. Only Infinity CM can read, but actually not properly write it. I wrote this message for CM developers. |
03-29-2009, 20:31 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @bencebacsi You are completely wrong regarding problem reason. Flash chip type is NOT important for this situation ! Problem is: you have flashed phone with firmware that is not good for your phone LCD type. You must use other firmware that support your phone LCD type. |
03-29-2009, 22:56 | #5 (permalink) |
Member: 829361 Status: Offline Thanks Meter: 107 | I flashed the phone with the same firmware what I downloaded from that phone earlier. The phone (both) worked properly before the flashing. So, that's simply impossible, that I flashed the phones with wrong version firmware. Even if I check "Smart" write and load the unmodified firmware, CM always rewrite some parts above 90%. |
03-30-2009, 00:07 | #6 (permalink) |
Freak Poster Join Date: Dec 2006 Location: location,location....
Member: 411486 Status: Offline Thanks Meter: 68 | i had this problem to with a china.i flashed the phone with same firmware and the phone was blank lcd but i made a backup before and a managed to write itback and returned the phone to the client.thatīs why in the present i avoid to make any flashes without reading the original flash and make a backup.....the CM have a lot of problems.I hope you will resolve your problem my friend.good luck |
03-30-2009, 21:17 | #8 (permalink) |
Member: 829361 Status: Offline Thanks Meter: 107 | The reason was language translation, as almost always at me. Yes, I used always the original flash backups only. The file, what I uploaded to rapidshare, is one of them. I used smart write first time with the original, but modified flash file. Than I tried the original (downloaded from the same phone) unmodified flash with smart write again, than without smart write. |
03-31-2009, 20:20 | #10 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
i affraid that now your phone will rescue only full backup taken from another working phone. | |
c1300 displays white screen after flash | gorgans | VygisToolbox | 5 | 12-12-2009 18:06 |
3650 blinks white screen after flash with latest version | mailhassan | WD2 & APE (Symbian Phones) | 13 | 12-19-2008 08:00 |
Auto shut off V3 turns white screen after flashing flash... | scion | Motorola P2k | 10 | 09-19-2007 10:31 |
7610 white screen after flashing a ppm | MELME | UFS2 + UFS3-Tornadoflasher | 29 | 05-05-2006 01:53 |
E720 - white screene after flashing | QMaro | NSPRO | 3 | 10-22-2005 11:45 |
