Old 03-10-2009, 15:34   #1 (permalink)
Member: 409004
Who can help me !!!
HOW UNLOCK ZTE A205 MTN IVORY COAST WITH INFINTY . I TRY MANY TIME BUT PHONE IS ALWAYS LOCK...HELP PLEASE...
COM3 [VCP0] selected
Device: Aiko 17G
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "sp-unlock"
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
Initializing[6223:8A05]...
CPU: MT6223
chip: 0011:0A8E:000C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25032501:29EA0000000000
flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
Initialize Done
Set baud...
230400
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: ZTENJ23_BW_96X64_07B_PCB01_GSM_MT6223_S00.FE-CD-MTN-P109A8V1_0_0B01.BIN
ver. sw2: FE-CD-MTN-P109A8V1.0.0B01, 00000000
ffs offset/size: 00300000/00100000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[ZTENJ23_BW_96X64_07B_PCB01_GSM_MT6223_S00.FE-CD-MTN-P109A8V1_0_0B01.BIN]...
file saved: C:\Program Files\InfinityBox\MModule\eeprom[ZTENJ23_BW_96X64_07B_PCB01_GSM_MT6223_S00.FE-CD-MTN-P109A8V1_0_0B01.BIN]_20090310-141145.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
error: phone is not locked or unknown eeprom
Patch required data Fail
Finished, time used: 66 sec
Remove/Install battery now !
Old 03-10-2009, 16:13   #2 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
Device: Aiko 17G
Action: "sp-unlock"
Boot...
19200 fixed
Connecting, wait...
CPU: MT6223
Boot Done
Initialize...
Initialize Done
Set baud...
230400
Set baud Done
How about to select correct model for unlock ?
Old 03-10-2009, 16:50   #3 (permalink)
Member: 409004
phone is allways lock it show " invalide sim" ...what dilemme ...
A friend unloc it by flashing ffs with UNKNOW eeprom and he do not want to help me ...oh my *** PLZ HELP ME I HAVE 50 PIECES TO UNLOCK ...HOW TO DO ???
module v2.67
Device: ZTE-A205
Action: "sp-unlock"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
status: FF
boot packet size: 0400
Boot Done
Initialize ...
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Check firmware integrity ...
identification#1 detection finished
ver. sw 1: ZTENJ23_BW_96X64_07B_PCB01_GSM_MT6223_S00.FE-CD-MTN-P109A8V1_0_0B01.BIN
ver. sw 2: FE-CD-MTN-P109A8V1.0.0B01, 00000000
sim-lock status: unknown
Check firmware content ...
Backup required data ...
file saved: C:\Program Files\InfinityBox\MModule\eeprom[ZTENJ23_BW_96X64_07B_PCB01_GSM_MT6223_S00.FE-CD-MTN-P109A8V1_0_0B01.BIN]_20090310-153408.B0E.bin
Patch required data ...
detection procedure completed
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
Finished, time used: 97 sec
Old 03-10-2009, 17:01   #4 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
Hi,
Try to make unlock with other unlock mode.
waiting for your results.
Old 03-10-2009, 17:16   #5 (permalink)
Member: 409004
ALLWAYS PHONE SHOW SIM INVALID
module v2.67
Device: ZTE-A205
Action: "sp-unlock"
unlock method: standard fast
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
230400
Set baud Done
lock area found
lock area found
Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
Finalization ...
Finalization Done
Finished, time used: 42 sec
Old 03-10-2009, 17:19   #6 (permalink)
Member: 409004
module v2.67
Action: read codes
unlock method: read codes
Model: ZTE-A205
19200 autodetect
CPU: MT6223
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: FE-CD-MTN-P109A8V1.0.0B01
Version: 07BZTENJ23_BW_96X64_07B
THIS PHONE DO NOT WHANT TO BE UNLOCK...
67 byte(s) read
imei: 3572890XXXX
connection Ok
180 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1122
Finished, time used: 10 sec
Old 03-10-2009, 18:53   #7 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
Hi,
What you see at phone LCD after you power-on phone with sim card ?
Are you sure that phone is still locked ?
if is still locked after all operations read full flash and send full flash backup to [email protected]
Old 03-10-2009, 19:46   #8 (permalink)
Member: 409004
OK I think weN WE kan panic there is a lot of error ...
Everything is OK ...HOW I TRY...
I copy eeprom OF ZTE A205 WHICH IS functional
and has never been locked since the manufacture
and I flash eeprom of ZTE A 205 WHICH IS LOCK
and phone has been unlock... it is strange
but it is the outcome that counts ...
is it normal that I do?
Old 03-10-2009, 21:07   #9 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
Hi,
If your phone works well no this means that everything is Ok.
Do not forget to check phone imei and repair it if need.
Who can help me! I want to unlock the machine is 9530, however, who can help me, it i mazeyu520 BlackBerry (RIM) 2 10-02-2009 09:39
who can help me,resolve my pro....help NO.7 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 05-01-2009 11:25
who can help me?!!! E335 is dead,where i can download flash file or backup file? wildtiger SYSOL Platform 1 09-02-2005 06:32
Who can help me!Who can help me! ksin2004 Samsung Flashers, Software, Firmware. 1 07-31-2004 13:50
Help, I need full retrofit for alcatel, who can help me!!! alro Alcatel & TCL Old Models 4 10-18-2001 10:09
Page generated in 0.37314 seconds with 8 queries
