why error? Card found: S/N : 20B8AC71 , v0118 Registered to: hamid200 Connect phone on selected interface... Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_1.2.4.3_059T985_IMEA_IN_variant.img Ok, Set : RM980_1.2.4.3_boot.img Ok, Set : RM980_1.2.4.3_cache.img Ok, Set : RM980_1.2.4.3_emmc_appsboot.mbn Ok, Set : RM980_1.2.4.3_emmc_appsboothd.mbn Ok, Set : RM980_1.2.4.3_fat.bin Ok, Set : RM980_1.2.4.3_oemsbl.mbn Ok, Set : RM980_1.2.4.3_oemsblhd.mbn Ok, Set : RM980_1.2.4.3_persist.img Ok, Set : RM980_1.2.4.3_preload.img Ok, Set : RM980_1.2.4.3_qcsbl.mbn Ok, Set : RM980_1.2.4.3_qcsblhd_cfgdata.mbn Ok, Set : RM980_1.2.4.3_recovery.img Ok, Set : RM980_1.2.4.3_system.img Ok, Set : RM980_1.2.4.3_udisk.bin Ok, Set : RM980_1.2.4.3_userdata.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_1.2.4.3_059T985_IMEA_IN_variant.img Ok, Set : RM980_1.2.4.3_boot.img Ok, Set : RM980_1.2.4.3_cache.img Ok, Set : RM980_1.2.4.3_emmc_appsboot.mbn Ok, Set : RM980_1.2.4.3_emmc_appsboothd.mbn Ok, Set : RM980_1.2.4.3_fat.bin Ok, Set : RM980_1.2.4.3_oemsbl.mbn Ok, Set : RM980_1.2.4.3_oemsblhd.mbn Ok, Set : RM980_1.2.4.3_persist.img Ok, Set : RM980_1.2.4.3_preload.img Ok, Set : RM980_1.2.4.3_qcsbl.mbn Ok, Set : RM980_1.2.4.3_qcsblhd_cfgdata.mbn Ok, Set : RM980_1.2.4.3_recovery.img Ok, Set : RM980_1.2.4.3_system.img Ok, Set : RM980_1.2.4.3_udisk.bin Ok, Set : RM980_1.2.4.3_userdata.img Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info HWDetails : 0x0000 , 0x0000 , 0x0000 , 0x0000 HWDetails : eMMC : VEN , OEM : , NAME : HWDetails : Failed to identify! File HW revision is : HW Revision V1 Processing : RM980_1.2.4.3_qcsblhd_cfgdata.mbn Partition Init Not Done Flash Error Break flashing! Phone disconected! Connect phone on selected interface... |
Hello. Re-install USB drviers. Charge battery completely. Close ALL Sw, which can use fastboot and adb ( managers and etc ) Then repeat operation. |
how to fast boot? adb |
Just open TaskManager and close all adb.exe and fastboot.exe, if they will be found in list. |
TaskManager adres taskmanager??? |
plz send here driver thankss |
Drivers on support area. Whole package. Install all from it. |
