02-14-2011, 13:56 | #1 (permalink) |
Banned Join Date: Nov 2009
Member: 1162712 Status: Offline Sonork: 100.1594855 Thanks Meter: 230 | why error when i flash micromax x265 Code: COM2 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Micromax-X265_WBG1000C_0101_PCB01_GPRS_MT6253_S00.1000C_0101_V1825.BIN_FLNPF38F3050M0Y3DF.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Micromax-X265_ffs_01.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 22 sec Remove/Install battery now ! |
02-16-2011, 14:17 | #5 (permalink) |
Member: 1162712 Status: Offline Sonork: 100.1594855 Thanks Meter: 230 | Code: COM10 [VCP0] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... advanced flash detection disabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 16 sec Remove/Install battery now ! |
02-16-2011, 14:38 | #6 (permalink) |
Member: 1162712 Status: Offline Sonork: 100.1594855 Thanks Meter: 230 | Code: COM10 [VCP0] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... advanced flash detection disabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 21 sec Remove/Install battery now ! |
02-16-2011, 14:40 | #7 (permalink) |
Member: 1162712 Status: Offline Sonork: 100.1594855 Thanks Meter: 230 | flashing ok but why not getting info or details Code: COM10 [VCP0] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware Micromax-X265_WBG1000C_0101_PCB01_GPRS_MT6253_S00.1000C_0101_V1825.BIN_FLNPF38F3050M0Y3DF.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Micromax-X265_ffs_01.B0E.bin nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: 1000C_0101_V1825 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... done number of cores: 2 loading files... number of areas: 2 done write... write core... Disconnect... done Finished, time used: 5 min 31 sec Remove/Install battery now ! |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
