((( why i can't connect J100 with infinity ))) can any one tell me one thing that why J100 of Se not connecting with INFINITY > i test the cable but not connecting when i plug the cable mobile's red light ( i think its showing charging light ) on and when INFINITY ask me for press power button i pressed but nothing happend Please tell me how can i connect Se J100 with infinity thanks Br Faisal_Computer |
which cable u r using m used cruiser or setool cable select comport which shows device manager set buad rate 115200 when soft ware says power on connect cable and press power on may be its work fro u |
cable that come with infinity 9: Gnd 10: phone Rx 11: phone Tx 12: yellow wire Br Faisal_Computer |
i just searched some people asked that UC10 cable of CRUISER is working fine on infinity if its true then Please post pinout of that cable thanks and one thing i just forget that i cuted test point !! Br Faisal_Computer |
hello! if red light goes On- this means phone in charging mode. in this condition it can not be booted. try to run soft and then connect cable. also check if battery is ok and right com port used |
thanks for reply..... !! 1) i was just charged bettery now when i plug bettery into mobile red light off 2) please tell me setting ( i was cutted that testpiont ) step by step 3) you want to say that cable must be plug in com 1 ( rts and cts ) Br Faisal_Computer |
Follow the instructions, Everything shld be done in a proper way. 1) Make Test Point as described by Infinity (If Required) 2) Connect InfinityBox and proper cable with infinityBox Run the proper software 3) Select Proper Com Port incase ur using USB Port check in Device Manage The port No. 4) Select Proper Baud Rate. 5) Select Proper Flash Files (If flashing Required) 6) Clicke Strat Button and when Software ask u for Press power Button just insert the cable. 7) If not detect automatically press and hold pwer btn as described by the software(Sometime says only press power button sometime says press and hold power button) NOTE : FOR EVERY ACTION BETTERY SHLD BE FULLY CHARGED. Take Care ENJOY |
i was try all these what you said but mobile not detecting and i also use com 1 its also not working Br Faisal_Computer |
why u r saying com 1 again and again if u don't know which com port to use better put here screen shot of device manager. so other can help u to select correct com port. br |
why u cut the track i mean test point i unlocked so many sets never use any test point just connect and unlock so now u need first repair ur cutted track and try again as infinity team said |
yes ...... let me sold it back and test it witch cable are you useing and Please post here pinouts of it Br Faisal_Computer |
