Old 04-30-2007, 08:02   #1 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,392
((( why i can't connect J100 with infinity )))
can any one tell me one thing that why J100 of Se not connecting with INFINITY > i test the cable but not connecting when i plug the cable mobile's red light ( i think its showing charging light ) on and when INFINITY ask me for press power button i pressed but nothing happend Please tell me how can i connect Se J100 with infinity thanks
Faisal_Computer
Old 04-30-2007, 08:15   #2 (permalink)
yousaf22us's Avatar
Member: 113943
Thanks Meter: 73
which cable u r using m used cruiser or setool cable select comport which shows device manager set buad rate 115200 when soft ware says power on connect cable and press power on may be its work fro u
Old 04-30-2007, 08:37   #3 (permalink)
Member: 151871
cable that come with infinity
9: Gnd
10: phone Rx
11: phone Tx
12: yellow wire
Faisal_Computer
Old 04-30-2007, 08:39   #4 (permalink)
Member: 151871
i just searched some people asked that UC10 cable of CRUISER is working fine on infinity if its true then Please post pinout of that cable thanks and one thing i just forget that i cuted test point !!
Faisal_Computer
Old 04-30-2007, 10:16   #5 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
if red light goes On- this means phone in charging mode.
in this condition it can not be booted.
try to run soft and then connect cable.
also check if battery is ok
and right com port used
Old 04-30-2007, 10:22   #6 (permalink)
Member: 151871
hello!
thanks for reply..... !!
1) i was just charged bettery now when i plug bettery into mobile red light off
2) please tell me setting ( i was cutted that testpiont ) step by step
3) you want to say that cable must be plug in com 1 ( rts and cts )
Faisal_Computer
Old 04-30-2007, 10:36   #7 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Follow the instructions, Everything shld be done in a proper way.
1) Make Test Point as described by Infinity (If Required)
2) Connect InfinityBox and proper cable with infinityBox Run the proper software
3) Select Proper Com Port incase ur using USB Port check in Device Manage The port No.
4) Select Proper Baud Rate.
5) Select Proper Flash Files (If flashing Required)
6) Clicke Strat Button and when Software ask u for Press power Button just insert the cable.
7) If not detect automatically press and hold pwer btn as described by the software(Sometime says only press power button sometime says press and hold power button)
NOTE : FOR EVERY ACTION BETTERY SHLD BE FULLY CHARGED.
Take Care
ENJOY
Old 04-30-2007, 10:50   #8 (permalink)
Member: 151871
Take Care
ENJOY
THanks for reply !!
i was try all these what you said but mobile not detecting
and i also use com 1 its also not working
Faisal_Computer
Old 04-30-2007, 10:58   #9 (permalink)
Member: 498330
why u r saying com 1 again and again
if u don't know which com port to use
better put here screen shot of device manager.
so other can help u to select correct com port.
br
Old 04-30-2007, 10:59   #10 (permalink)
yousaf22us's Avatar
Member: 113943
Thanks Meter: 73
why u cut the track i mean test point i unlocked so many sets never use any test point just connect and unlock so now u need first repair ur cutted track and try again as infinity team said
Old 04-30-2007, 11:04   #11 (permalink)
Member: 151871
yes ...... let me sold it back and test it
witch cable are you useing and Please post here pinouts of it
Faisal_Computer
Successfully worked on J100 with Infinity?Share Us meisam Infinity-Box 114 01-01-2010 17:25
why i can't connect this phone?? kevin168 Infinity-Box 15 11-14-2007 22:39
why i can't use MiniGPS with some patch. blazefr Siemens-Benq Flash Patching 0 06-02-2005 08:09
Problem... Can't connect Gthing with Lg3 :( need help the_frightener LG 1 05-17-2005 10:47
LG 5300 why i can't Connect my Phone ?? newland LG 2 08-05-2003 18:28
Page generated in 0.34982 seconds with 8 queries
