11-12-2007, 21:33 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
11-13-2007, 16:11 | #6 (permalink) |
No Life Poster Join Date: Sep 2005 Location: INDONESIA Age: 38
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | yeah i'll give u the info, please make some good answer, not just same answer always like that, 1. Chinese Phone Similiar with N73 with DKU-2 connector like the original ones 2. MT6226BA CPU id 3. I'll give u already Phone PCB picture, sorry for bad quality 4. I think i didn't need to attach, just same like N73 5. Bottom, was same like the original, i can plug Original DKU-2 cable into this connector 6. i'll give u the phone Ground and Vcharge and about the hint that u tell us when we search all the pinout, i already try it, try one by one to find right TX and RX. but actually i cant find it yet. br, kevin168 |
11-13-2007, 16:17 | #7 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | will, i guess no one can give you a clear answer unless he/she tested this kind of board and found pinouts but my advice to you, after you found GND and PWR you have 8 pins left to test power on the phone and test the lines which give 2.7-2.8v or 1.6-1.7v these should be the Rx Tx lines, you need to search for diffrent combinations after you find the lines with voltages i mentioned. hope its helpfule information BR Mansi |
11-13-2007, 18:44 | #8 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | i had already found the pin out for my phone. there is the pic.. i also send full backup data and upload in rapidshare, please check it infinity team, http://rapidshare.com/files/69466527...33_newCopy.rar br, kevin168 |
11-14-2007, 00:12 | #9 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.1E1E4B98.[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN_8532 097B].rpl New firmware detected: D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished device-id: 1E1E4B98 protocol ver: 04 ver. sw1: D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN ver. sw2: D421_V1.00 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN]_20071113-230006.B0E.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _1E1E4B98_D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_0 0.BIN_8532097B_20071113-230012.B0X.bin Finished, time used: 73 sec Remove/Install battery now ! |
11-14-2007, 00:13 | #10 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: D421_05C_HW Software version: D421_V1.00" Software date: 2005.04.12 Barcode: 081701MT012345678901235432 imei: 35640601620xxxx Finished, time used: 23 sec Power off phone now ! |
11-14-2007, 00:15 | #11 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.1E1E4B98.[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN_8532 097B].rpl New firmware detected: D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished device-id: 1E1E4B98 protocol ver: 04 ver. sw1: D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN ver. sw2: D421_V1.00 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detection phase #3... .................................................. .............. done detecting structure pass 1... .................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete eeprom element #1 detected ok file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _1E1E4B98_D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_0 0.BIN_8532097B_20071113-231006.B0X.bin Finished, time used: 61 sec Remove/Install battery now ! |
11-14-2007, 00:16 | #12 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.1E1E4B98.[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN_8532 097B].rpl New firmware detected: D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished device-id: 1E1E4B98 protocol ver: 04 ver. sw1: D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN ver. sw2: D421_V1.00 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [flash[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_00.BIN]_20071113-231510.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _1E1E4B98_D421_05C_PCB01_GPRS_MT6226_S01.D421_V1_0 0.BIN_8532097B_20071113-231635.B0X.bin Finished, time used: 345 sec Remove/Install battery now ! |
11-14-2007, 19:31 | #14 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | yes phone was restarting at the first now all was OK when do Format FFS job, and write the Imei, nice job from Infinity, but still tired when search for new Pinout. br, kevin168 |
11-14-2007, 21:51 | #15 (permalink) |
Freak Poster Join Date: Jan 2007 Location: ALGERIA
Member: 431529 Status: Offline Thanks Meter: 18 | HI ALL i have trouble with this model of N73 it s a copy of nokia n73 but rh64 i cant find its pinouts please help 1. Chinese Phone Similiar with N73 with DKU-2 connector like the original 2. MT6226BA CPU id PRODUCT IMAGE AT http://rapidshare.com/files/69737669/N73_RH64.JPG THANX |
why i can't unlock this n91 | nyong | NoooX Box | 2 | 10-25-2008 19:38 |
why ustpro can't unlock this poor phone c180 | long way | UST Pro II | 2 | 10-03-2008 10:03 |
((( why i can't connect J100 with infinity ))) | Faisal_Computer | Infinity-Box | 10 | 04-30-2007 10:04 |
LG 5300 why i can't Connect my Phone ?? | newland | LG | 2 | 08-05-2003 17:28 |
