03-07-2011, 13:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Why i got "wrong Cs" error everytime,when i read flash? Code: COM10 [Serial2] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9888:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2D0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x0001ACDC, retry... read error recovered warning: wrong cs at 0x000368DC, retry... warning: wrong cs at 0x000368DC, retry... warning: wrong cs at 0x000368DC, retry... warning: wrong cs at 0x000368DC, retry... warning: wrong cs at 0x000368DC, retry... warning: wrong cs at 0x000368DC, retry... warning: wrong cs at 0x000368DC, retry... warning: wrong cs at 0x000368DC, retry... warning: wrong cs at 0x000368DC, retry... error: too many retries during read operation search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.27, database date: 20.11.2009): GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: GOLDDRAGON23D_09B_PCB01_GPRS_MT6223_S00.GD1101_V2_FDT_T32T3W0_DSIM_L3_V10.BIN project-id: GD1101_V2_FDT_T32T3W0_DSIM_L3_V10, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 error: wrong answer: 4D error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: FF : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation aborted by user operation aborted Finished, time used: 45 sec Remove/Install battery now ! i need to repair "no license to produce". i am sure, cable connection is 100% ok. becaues in format i do not have any problem. problm occures only when i try to read flash. Help me Supporters |
03-07-2011, 14:01 | #2 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
But try to read flash with low speed minimum speed. if not work then try to change box port it must be under 10 comport | |
The Following User Says Thank You to alamgarh For This Useful Post: |
03-07-2011, 14:42 | #3 (permalink) | |
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Quote:
does all phone have hardware problem?i tried it with many phones, now trying with slow speed will post result. | |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
