Old 02-27-2020, 08:29   #1 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
Why the old smallphone phone soft no work
Hi infinity box team
For some time I noticed that the old programs that are in the shell no longer work. I mean the: motorola (c .., w ...) the small lg, zte ... are all impossible with my box. only cm2, cm2mt2, cm2sp2 ... in short the last update only works. Can you correct this?
Old 02-27-2020, 09:30   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Hello,
post logs or screenshot for each module which doesn't work for you.
Old 02-27-2020, 11:10   #3 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
for all old phone it display
but for the new soft, the new update , it work
thk
Old 02-27-2020, 16:26   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
thk
Try here http://forum.gsmhosting.com/vbb/11254915-post3.htm
or
l
https://forum.infinity-box.com/viewtopic.php?f=3&t=1095
The Following 2 Users Say Thank You to Kirumira For This Useful Post:
Old 02-28-2020, 15:16   #5 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
thk for your help but it display another error.
need again help
Old 02-28-2020, 17:56   #6 (permalink)
Member: 1043909
Thanks Meter: 60,926
Do you have Infinity-Box/Dongle or doe you have Infinty actiavtion for BEST ?
Old 02-29-2020, 08:52   #7 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
I have Infinity Dongle cm2 + activation for BEST. and i have infinity box whithout simcard but i don t used it because it damage my simcard if i put inter. it is because of that, i add my cm2 to my best dongle since un year.
Old 02-29-2020, 09:10   #8 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
The dongle you are using now is NOKIA BEST-DONGLE true or False?
Old 02-29-2020, 09:57   #9 (permalink)
Member: 1043909
ok sir, I understand everything about hardware problem. I can suggest you do not use faulty hardware.
What is your dongle S/N ?
Old 02-29-2020, 10:04   #10 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
it is NOKIA BEST-DONGLE.
Old 02-29-2020, 10:05   #11 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
Serial No (S/N): 2933876D
Old 02-29-2020, 10:59   #12 (permalink)
Member: 1043909
This dongle is a [BEST] dongle with Infinity-Box/Dongle activation.
So you should apply at least first fix as per instruction https://forum.infinity-box.com/viewtopic.php?f=3&t=1095
result ?
Old 02-29-2020, 11:39   #13 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
i already do it and i have this last error
Old 02-29-2020, 12:00   #14 (permalink)
Member: 1043909
uninstall folder with bird software, delete whole folder, install again. After that Download [BEST] Fix pack and open readme.txt file for instruction
result ?
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 02-29-2020, 14:20   #15 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
all is ok thk for your asssistance
Page generated in 0.23374 seconds with 9 queries
