05-25-2008, 13:08 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: KERALA
Member: 609370 Status: Offline Thanks Meter: 13 | why second sim not work after format ffs? as usual i did format ffs.now first sim ok.second sim ""INSER SIM"" i backup flash and then flashed using another flash file.still the same-so i think it is EEPROM AREA damage.am i right? backup eeprom file details as below backup_eeprom[E553_XZY1PA2_E553_GPRS_MT6226_S01.V23_00_0.BIN]_20080525-165943.B0E(481kb) i need good above file. or any other way to again work both sims? help me thank u |
05-26-2008, 14:47 | #5 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 51
Member: 62419 Status: Offline Thanks Meter: 66 | yes i write imei like good ... all ok ... but always after 3 days max phone return same problem... and my customer is please wath is the solution , i tray write imei with 3 mode.. no success no solution to find original imei ?... |
05-26-2008, 19:11 | #9 (permalink) | |
Member: 609370 Status: Offline Thanks Meter: 13 | Quote:
did as u said-after it also INSERT SIM. SO DID REPAIR SECURITY AREA-LOG AS BELOW COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair security area Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:C026A75 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.268CDD97.[E553_XZY1ARTHRUTR_E553_GPRS_MT6226_S01.01_1.BIN_7C B64CB5].rpl identification#1 detection finished device-id: 268CDD97 identification#1 protocol ver: 04 ver. sw1: E553_XZY1ARTHRUTR_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_XZY1ARTHRUTR.01.1, 4AB34983 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _268CDD97_E553_XZY1ARTHRUTR_E553_GPRS_MT6226_S01.0 1_1.BIN_7CB64CB5_20080526-233756.B0X.bin Finished, time used: 128 sec Remove/Install battery now ! BUT STILL IN INSERT SIM | |
n73 2nd sim problem even after format ffs | sorinm | Infinity-Box | 3 | 02-02-2008 20:32 |
CECT T689 After format FFS work only with 1 sim | snsoftkiller | Infinity-Box | 12 | 11-04-2007 21:40 |
p910 2G sim not working after unlocking | parveen kumar | UST Pro II | 2 | 12-25-2006 14:06 |
