03-11-2010, 10:38 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: facebook.com/sMARTyRuLezZzz Age: 34
Member: 1080440 Status: Offline Thanks Meter: 606 | Club 90 Need Help -->New Problem <----- here iz log COM5 [VCP1] selected module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:AF03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.95753604.[BB13_NTP_PCB01_GPRS_MT6225_S00.BB13-1_BLE_L8EN_217_080812_HRILI9320_SIV0_WI75_CTF_BT_F M.BIN_2221C3F6].rpl rom info detection finished device-id: 95753604 rom info ver: 04 sw version: BB13_NTP_PCB01_GPRS_MT6225_S00.BB13-1_BLE_L8EN_217_080812_HRILI9320_SIV0_WI75_CTF_BT_F M.BIN project-id: BB13-1_BLE_L8EN_217_080812_HRILI9320_SIV0_WI75_CTF_BT_F M, F6C32122 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: B0001D00000000:B0001D00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: B0001D00000000:B0001D00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\B B13_NTP_PCB01_GPRS_MT6225_S00.BB13-1_BLE_L8EN_217_080812_HRILI9320_SIV0_WI75_CTF_BT_F M__system_log_95753604_2221C3F6_20100311-143247.B0X.bin Finished, time used: 1 min 11 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! FRIEND PROBLEM IZ I FORMAT WITH INFINITY N WRITE ITS ORIGIONAL FRIMWARE N MANY MORE FRIMWARE WHICH I DOWNLOAD WITH SUPPORT BUT WHEN MOBILE IZ ON N I MAKE A CALL ANY NUMBER MOBILE OFF & RESTART I ALSO CHANGE IMEI NUM Code: Action: "repair imei" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 350724302143335 verification Ok Finished, time used: 9 sec Remove/Install battery now ! BUT THE PROBLEM IZ SAME I DONT UNDERSTAND ABOUT THIZ PROBLEM SO PLZ INFINITY TEAM TELL ME NOW WAT I DO........ |
03-11-2010, 14:28 | #3 (permalink) |
Member: 1080440 Status: Offline Thanks Meter: 606 | yea sir i call it 112 but also mobile restart ...............so plz help.........................................INFIN ITY TEAM....!!!!! |
03-18-2010, 11:30 | #7 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 50
Member: 178616 Status: Offline Thanks Meter: 90 | need club 90 flash file plz dear infinity team i need club 90 flash file its urgent plz help me .. BB13_NTP_PCB01_GPRS_MT6225_S00.BB13-1_BLE_L8EN_215_080709_HRILI9320_SIV0_WI75_CTF_BT_F M__system_log_F043FC28_2BF500EF_20100314-014609.B0X.bin |
03-19-2010, 20:02 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
you can try this flash file. but first make full backup (read full flash on speed 921600) and next try to solve your problem by format FFS compete flashfiles/ChineseMiracle/_MT6225/BB13_NTP_PCB01_GPRS_MT6225_S00.BB13-1_BLE_L8EN_217_080812_HRILI9320_SIV0_WI75_CTF_BT_F M__Club-90_16m_En_Ru_Fr_Id_Th_Vn_Farsi_Ar.B0M.bin | |
03-21-2010, 17:57 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! as you saw, adviced by me file has small difference with your original file. "215" & "217" as soon as version "217" can not replace original one- you must search for excatly same version flash file. |
need help update problem! | sas-pc | Smart-Clip | 3 | 08-08-2008 08:10 |
Need help strange problem with Pc | c_ahmad79 | Off Topic Zone | 2 | 04-30-2008 18:52 |
RH-86 Nokia 1600b Need Help Unlock Problem | frankrizzo | MT-BOX | 4 | 01-06-2008 15:50 |
need help e630 problem | zata222 | Samsung Hardware Repair | 4 | 06-23-2006 01:15 |
urgent need help twister problem | moncef | Twisterflasher | 2 | 02-01-2005 11:13 |
