02-13-2018, 15:36 | #1 (permalink) |
Freak Poster Join Date: Feb 2015
Member: 2349228 Status: Offline Sonork: 34610 Thanks Meter: 19 | WIKO jerry 2 7.0 problem Frp 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
02-13-2018, 20:08 | #3 (permalink) |
Member: 2349228 Status: Offline Sonork: 34610 Thanks Meter: 19 | 1st : Move MTK_AlllnOne_DA_SP in C/derive CM2 MTk Boot Folder 2nd : Add scatter file in CM2 Scatter Thats it |
The Following 3 Users Say Thank You to dehmanigsm For This Useful Post: |
03-05-2018, 17:47 | #4 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 926208 Status: Offline Thanks Meter: 71 | THANK YOU dehmanigsm IS OK Done with https://mega.nz/#!knhDiCJY!Ad1UulvNZ...fE8jAi2UPOM0Qc Card found : S/N : XXXXXXXX , v0136 Chinese Miracle II [MTK module] v 1.58 [SCATCHECK] : Missing File : C:\Documents and Settings\khassene\Bureau\MT6580 Sec-Boot CM2 100% Solution\MT6580 Sec-Boot CM2 100% Solution\Scatter + preloder\lk.bin [SCATCHECK] : Scatter wrong or incomplete. Use Factory or CM2MTK Scatter! Start at : [05/03/2018 / 17:35:53] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 443 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 150100464536324D42030674CEC9741D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26E [eMMC] : FLASH_CID : 150100464536324D42030674CEC9741D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xCE1706B969C321D0ACBCFDEA855FF26F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : WIKO ProdName : v2610 ProdModel : JERRY2 Device : v2610 AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-n0.mp2-V1_tinno6580.we.n_P136 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Finish at : [05/03/2018 / 17:36:01] Start at : [05/03/2018 / 17:36:08] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 443 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 150100464536324D42030674CEC9741D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26E [eMMC] : FLASH_CID : 150100464536324D42030674CEC9741D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xCE1706B969C321D0ACBCFDEA855FF26F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:01:17 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to khassene01 For This Useful Post: |
03-05-2018, 18:03 | #5 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Hi, here's the secure boot wiko jerry 2, in case someone wants it or needs it, thanks Wiko_Jerry2_Boot |
The Following 3 Users Say Thank You to Franky_36 For This Useful Post: |
01-27-2019, 18:08 | #10 (permalink) |
No Life Poster Join Date: Nov 2006 Location: algeria
Member: 395094 Status: Offline Thanks Meter: 58 | PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : Wiko : jerry 2 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_1640_V2610AN_TRUNK_01.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019061344738641CA532D9743785 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A51C64853774D9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x1D2000000 [ 7,28 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A27014BEBDFE3DB65271891D37616D4A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : alps-mp-n0.mp2-V1_tinno6580.we.n_P136 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-07-05 Build Time : 1505229648 Board Platform : mt6580 Product Model : JERRY2 Product Brand : WIKO Product Name : v2610 Product Device : v2610 Product Manfct : WIKO USERDATA : PLAIN ( NOT encrypted ) Done! Elapsed: 00:00:30 Operation : SP Unlock [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : Wiko : jerry 2 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_1640_V2610AN_TRUNK_01.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019061344738641CA532D9743785 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A51C64853774D9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x1D2000000 [ 7,28 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A27014BEBDFE3DB65271891D37616D4A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 1024 | CNT : 5 | CODE : 87654321 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Direct unlock done! Done! Elapsed: 00:00:36 |
The Following User Says Thank You to farouk842000 For This Useful Post: |
01-28-2019, 07:04 | #11 (permalink) |
Freak Poster Join Date: Dec 2014 Location: NIGERIA
Member: 2312129 Status: Offline Thanks Meter: 139 | This is rubbish [QUOTE=khassene01;13001990]THANK YOU dehmanigsm IS OK Done with https://mega.nz/#!knhDiCJY!Ad1UulvNZ. You guys are just dropping da in forum for other tool believe me you guys are spoiling this work nothing else that DA is difficult to get instead of uploading it to server you can't find da in inferno section any DA in their server don't work with others box only for inferno believe me CM2 dongle is too cheap need to increase the price like SIGMA or FURIOUSGOLD most crack users need does DA and many crack users has CM2 because its the cheapest and it does many device I need to talk to one of this infinity developers |
01-28-2019, 08:18 | #12 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | [QUOTE=Elasunuas;13524702] Quote:
