10-23-2017, 22:10 | #1 (permalink) |
Freak Poster Join Date: Feb 2015
Member: 2349228 Status: Offline Sonork: 34610 Thanks Meter: 19 | wiko KENNY MT6737 frp problem remove frp with cm2 *da error securityboot boot not accepted boot error , http://a.up-00.com/2017/10/150879291289521.jpg |
10-23-2017, 22:53 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,777 | Quote:
may be easy solution. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 4 Users Say Thank You to Brka For This Useful Post: |
10-24-2017, 07:55 | #3 (permalink) |
Member: 2349228 Status: Offline Sonork: 34610 Thanks Meter: 19 | i hope ... __ Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! ___ |
10-24-2017, 08:31 | #4 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | Quote:
see video here CM2 MTK Boot Error Fix File Android 7.X Read Done - Free Firmware BD | |
The Following User Says Thank You to Pastime_GSM For This Useful Post: |
10-24-2017, 21:00 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | Because of too many amateur-Chinese-box makers these days, I sent you DA Agents via PM. Try it and post results. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
10-25-2017, 11:35 | #9 (permalink) |
Member: 2349228 Status: Offline Sonork: 34610 Thanks Meter: 19 | Best Team done : Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32584E0B040142018C33B2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4201040BB2332401 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA3F6A391845AB709CA063AB5AF3758F6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : WIKO ProdName : v3913 ProdModel : KENNY Device : v3913 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_tinno6737m.35.n_P139 Done! |
The Following 3 Users Say Thank You to dehmanigsm For This Useful Post: |
10-26-2017, 00:50 | #11 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | Because of too many amateur box makers today, which use others work as their world's first, it will stay exclusive for Infinity CM2 MTK v2.0. Be patient. Update coming very soon. b.r. Alex
The Following 9 Users Say Thank You to Brka For This Useful Post: |
