03-09-2016, 00:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Wiko Lenny dead after flash I got the phone stuck at wiko Logo. Did factory reset with cm2mtk and problem continued. I flashed the phone with a firmware I have read from other working phone in scatter format. This is a routine procedure which we make every day, after flashing the phone, the set is dead for good, no more detection via USB, nor pressing any button while connecting, with or without battery doesnt matter. no response to charger, no signal of life at all. I used this firmware: MT6572__WIKO__LENNY__s5201ap__4.4.2__ALPS.KK1.MP7. V1 is there any way to revive this via atestpoint or something ? Flashing Log Code: Start at : [07/03/2016 / 12:26:41] Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 94 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48344732611101DD288ACD7201 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101DD288ACD7201 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Disabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3604 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5201ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:20 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:46 Reconnect Power/Cable! Finish at : [07/03/2016 / 12:29:27] logs for BLU Code: ========================= Start ========================= 07/03/2016 / 12:06:08 ========================================================= Card found : S/N : 7557D196 , v0129 Chinese Miracle II [MTK module] v 1.40 Scatter Load Ok , BaseBand : MT6572 , Project : s5201ap_blu_open , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Start at : [07/03/2016 / 12:07:20] Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 94 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040503A2077D229F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2077D229F [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s5201ap_blu_open , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4027 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5201ap_blu_open.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:34 Update RomInfo done Done! Elapsed: 00:02:58 Reconnect Power/Cable! Finish at : [07/03/2016 / 12:10:18] Need ideas, help... |
03-10-2016, 00:31 | #2 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | I see... still no replies from anyone, no ideas, no thoughts... OK I dismantled the phone, and found KCOL0 TP, shorted it to Ground and connected USB cable, Phone is detected.... am a bit more relaxed now. Tried to write preloader from same firmware and got this Code: Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48344732611101DD288ACD7201 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101DD288ACD7201 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] STORAGE : BL NOT support this eMMC! Select Correct One! Done! Elapsed: 00:00:09 Reconnect Power/Cable! Anyone has a different preloader for this phone ? this is the preloader file in the firmware. preloader_s5201ap.bin |
03-10-2016, 06:31 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Sometimes I need sleep and back to real life About problem : You can use ANY compatible MT6572 phone preloader. CM2 show list of ID's on selection. About phone exactly - mostly like it have new HW, which are not compatible with old version. Anyway - strange about CM2 flashed that FW to phone. It should check any byte of eMMC ID to make sure. Will revise it for future updates. |
03-10-2016, 21:13 | #5 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Maybe I unchecked the hw check checkbox, am getting used to this bad practice lately, this bad practice came to be used because of some false alerts from cm2 on some phones. I checked yesterday on needrom.com and I saw files for wiki Lenny and wiko Lenny 2. Am downloading and will try preloader from that wiko Lenny 2 firmware... Enviado desde mi SM-N920T mediante Tapatalk |
03-10-2016, 21:13 | #6 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote: Enviado desde mi SM-N920T mediante Tapatalk | |
03-11-2016, 01:25 | #7 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hi Got the files down from needrom. the suspicious archive I was talking about (Lenny 2) I extracted it, and the preloader file diuffers from all other archives. preloader is: preloader_s5030.bin I havent tried to write it yet... any comment? |
03-14-2016, 17:36 | #10 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | ok just tried, this time, there is a match for the CID on both preloader and phone, but is not writing... Code: User selected Preloader file : preloader_s5030.bin Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] FlashID [1] CID : 150100464A32374D42 , Name : FJ27MB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 90014A483447326111 , Name : H4G2a , Vendor : 90 , [HYNIX] FlashID [3] CID : 150100463832324D42 , Name : F822MB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48344732611101DD288ACD7201 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
03-14-2016, 17:46 | #11 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | Since preloader is alive, why not try using Sp flash tool plus officially matched stock rom? Sent from my TECNO_P5_PLUS using Tapatalk |
03-14-2016, 17:57 | #12 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Preloader is not alive: Preloader Status : Not active (Erased) I have to use Testpoint to force preloader and yes, I will try flashing with spflashtool via testpoint |
