GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   wiko rainbow (https://forum.gsmhosting.com/vbb/f296/wiko-rainbow-2105852/)
MDK23 06-24-2016 01:56
wiko rainbow
Operation : Flash [ v1.51 ]
======= Flash
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer  : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048602A47A9BB103
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048602A47A9BB103
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID    : 0xC4CD9207CBAAD44C25892BF71D825DAF
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : wiko , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify :  Disabled
Setting : HW verify :  Disabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : Unknown (not supported or without battery)
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wiko.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:23
Reconnect Power/Cable!
MDK23 06-24-2016 02:14
i repair bootloader BL the same
i Try to make Flash Erase the same
User selected DumpFile , extracted : preloader_wiko.bin
Start  at : [24/06/2016 / 01:29:29]
Operation : Init Preloader [ v1.51 ]
Supported HW by Preloader :
FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX]
FlashID [1] CID : 1501004B355530304D , Name : K5U00M , Vendor : 15 , [SAMSUNG]
FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA]
FlashID [3] CID : 90014A483847326404 , Name : H8G2d , Vendor : 90 , [HYNIX]
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer  : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
BL : Storage supported by BootLoader!
Sending BootLoader ...
PartTable Init Failed, Reflashing required!
All Done
Done!
Elapsed: 00:00:14
CrKdz13 06-24-2016 02:34
Emmc test ?
Wbr
Ouzigzag 06-24-2016 13:42
Your EMMC is in "READ ONLY" state or corrupt.
Try to change EMMC and reflash again.
Wiko RAINBOW has faulty EMMC this kind of problem cames sometimes.
JayDi 06-24-2016 14:48
As example - exactly same HYNIX ic :
http://forum.gsmhosting.com/vbb/f296...-help-2106024/
MDK23 06-25-2016 01:12
its working before
the phone its virus infected
f164 06-25-2016 12:55
Originally Posted by MDK23 (Post 11893203)
its working before
try spflash tool the same happens with me, it is some kind of bugs in infinity but after trying sp flash tool flash passes normally because the phone was working and with viruses
multiomc 01-01-2018 17:20
pls poit wiko rainbow dead
Page generated in 0.11669 seconds with 6 queries
