07-04-2007, 22:09 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: NW USA
Member: 304779 Status: Offline Thanks Meter: 5 | Will the infinity box unlock a Cingular C139?? |
07-05-2007, 00:31 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | some c139 can be unlocked ordinary way (w/o open), some of them must be opened and special track cutted, some of them (latest) must be opened, CPU desoldered and then unlocked. You can get more info if you will search about "C139 8.8.17" |
08-08-2007, 05:46 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Jamaica Age: 41
Member: 162707 Status: Online Thanks Meter: 66 | hello InfinitySupport I have 5 C139 v1.9.24 by cingular. Can your tool unlock it? I have tried cutting the track and the phone still turn on. Do you gurantee that when we successfully cut the track and flash it, it will connect to the infinity box? Please I am awaiting your speedy response. Oh one more thing, how do we know the difference of the tracfone (latest) 8.8.17 and the old 8.8.17? I have killed phone thinking it was the normal 8.8.17 and cut the track now the phone still wont connect and now it's dead!! I don't have the heat gun to take off cpu. Please reply soon. Thanks Venom |
08-08-2007, 09:30 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think you porblem is not new type PCB, but faulty cable. please check panasonic G50 cable in cable selector. picture 2 and 3 is examples how you need to modify cable to make it fit in phone better. Please modify your cable this way. Try to push and hold it inside phone while you connect it with soft. Also, are you sure that you selecting right comport? Have you tried to modify latency value how it is discribed in C:\Program Files\InfinityBox\Moto01\Documentation document named C1xx_C139_advanced_port_settings If you cut test point and phone stoppped to work- this means you did all right, no need to remove Ball from leg N1. Just use "cutted track" option in program and flash phone |
10-02-2007, 23:25 | #5 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | i got one of those cingular too and cant be connected even if i try with other devices, i there any solution for this version, should i try cut trac like tracfone version please give me answer, and by the way is not the cable i try with one cable and with another that i just bought a new one |
10-03-2007, 15:00 | #7 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 41
Member: 84130 Status: Offline Thanks Meter: 8 | Cingular's C139 FW: 1.9.24 can't be unlocked, trust me isn't cable problem or bad TP, I unlocked to many C139 normal and via TP and always fine. It's the same as Trackfone with FW: 8.8.17, when you cut the track the phone still turn ON and can't connect with the Box. I think CPU desoldered is needed. |
10-06-2007, 18:32 | #9 (permalink) | |
I am sad to say but this your message just show your zero-beginning level. If you want to get real info you must use "search" button in this forum. | |
10-09-2007, 21:07 | #10 (permalink) |
Freak Poster Join Date: Jan 2007 Location: usa Age: 39
Member: 438379 Status: Offline Thanks Meter: 0 | i know im not an expert and i never claim to be, but thanks for the comment. i know the above method doesnt make any sense, because the phone has to boot before being unlocked or flashed. i just post it because a few people mentioned it works on cingular c139. |
03-06-2008, 16:58 | #11 (permalink) |
Junior Member Join Date: Feb 2008
Member: 714676 Status: Offline Thanks Meter: 0 | Hello InfinitySupport I have opened 2 C139 Motorola Trackfone SW: 8.8.17 and Cingular SW: 1.9.24 - Basically I have ruined it to see the inside. I found out that it is not easy to Cut Track - remove the CPU is even harder. It is total different from the video in youtube - To me without special tools then it is the impossible to do the job. Can you recommend where I may get the tools to use with Infinity Box to Unlock C139. Thanks. |
03-06-2008, 17:29 | #12 (permalink) |
Member: 714676 Status: Offline Thanks Meter: 0 | Hello Cubafreak, Have you tried to remove the C139 CPU - Yes, I did. It is impossible. Why don't you try one and see. InfinitySupport and Infinity Help stated that: Cut Track, Remove CPU, Resolder Track, Reballing . . . Infinitysupport, Infinityhelp please provide some link so that we can get the tools to do the job. The CPU removing is already an impossible job - I tried it. Resolder balls . . . the space is about 0.6mm for Cut Track and Resoldering. Where do we get the tools to do this job. $15,000 Laser Solder Machine ? ? ? InfinitySupport, InfinityHelp you have done the job. Can you please provide some link so that we can buy the "Special Tools to do the job? Thanks |
03-06-2008, 19:58 | #13 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Dominican Republic
Member: 482218 Status: Offline Thanks Meter: 119 | to unlock cingular version just choose method 4, pretty easy. tracfone ones only by cutting track or removing ball. i have done this with out removing cpu but theres a big chance the phone would have problems like no vision or ni backlight. |
03-06-2008, 21:33 | #14 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | @wildwolf72 In fact it's not easy work and for many people is much more easy to return phone to customer than make this kind of job. It's need to have good hardware repair knowledges to unlock phones by this method. As about tools: at least you need to have good microscope and BGA soldering station. Can't give you any link because my own BGA soldering skills is not so good (main work is in little bit other fields), hope somebody can post some links here. |
03-06-2008, 22:46 | #15 (permalink) |
Member: 714676 Status: Offline Thanks Meter: 0 | Hi el_venga, Thanks for the response, Regarding method 4 for cingular - Can you please tell me a little detail about this method. Thanks, PS. Thanks InfinityN - Yes I got a microscope but the thing is "no tools small enought to do the job |
First in the world : Infinity Box unlocks Orange Vegas & Tmobile Vairy | Infinity-Box | Main Sales Section | 0 | 04-27-2009 15:47 |
Will the Martech box going to be dead? | nishaon | Martech CLIP / Box / Key | 61 | 10-04-2008 19:52 |
Will the universal box change imei on 1100 and 6230? | ovallito | Universalbox | 2 | 01-26-2008 21:31 |
for Team Infinity-box new firmware motorola c139, c115 y c122 | crowys | Infinity-Box | 6 | 07-26-2007 01:06 |
Please improve the infinity box to brush the machine speed | linfen | Infinity-Box | 3 | 05-18-2007 22:03 |
