02-24-2016, 11:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Satkhira khulna Bangladesh
Member: 1716947 Status: Offline Sonork: 100.1661965 Thanks Meter: 195 | Winmax W800 plus 6572 smart Av and Apps manager Not Done Please team solved it Operation : Remove Viruses [SmartAV] [ v1.41 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447582146710091EF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447582146710091EF [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 51E90D789A63A0B7D80C60F0B6177DD9 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 9 Removing infected files and scripts ... SmartAV Report : Removed 9 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:00:50 Reconnect Power/Cable! Operation : Scan APPs [DDirect] [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447582146710091EF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447582146710091EF [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 51E90D789A63A0B7D80C60F0B6177DD9 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictionary Collect done : 0x0009 [DDCleaner Info] : Files to remove : 10 [DDCleaner Info] : Additional garbage detected : 1 Removing files ... [DDCleaner] : Removed 10 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:00:54 Reconnect Power/Cable! Every time same show removed but when I scan again then same please tell me how to solved . |
