04-18-2009, 05:39 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: NZ
Member: 862105 Status: Offline Thanks Meter: 6 | i-mobile 903 how to flash and unlock? i got one i-mobile 903 this phone had phone lock code also network lock, tried infinity software can detech the phone but cant do any unlock and usercode reset, infinity support had one file to flash but dont know how to flash, pls advice thanks in advance |
04-18-2009, 06:46 | #2 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
for remove phone lock code... u can do just format operation for network lock just press sp-unlock use method : standard for flash .. just read info firmware the phone... then look in support find the same firmware.... then just flash it, better u read full flash before u flash the phone regards notgood | |
04-18-2009, 09:35 | #3 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
How to flash and unlock with Ub box ? | mma | Universalbox | 5 | 11-03-2008 06:47 |
How to flash and unlock C139 with UBL? | CRUELTY | Ultima Box Light | 1 | 04-07-2007 20:13 |
How to flash and unlock T630? | whiteswang | Cruiser Suite | 9 | 05-29-2006 15:50 |
How to flash and unlock Se T200 | kassongo | Sony Ericsson | 2 | 03-29-2006 21:21 |
how to flash and unlock x6x phones fast way? | gsmsalers | S-Gold Based Phones | 0 | 01-20-2005 12:50 |
