05-21-2018, 13:43 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | world 1st Doogee x10 MT6570 vibrate only revive with CM2 FLASH Code: Operation : Write Flash [ v2.00 r2 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :9 [FL] : Set : preloader_jc45btlc.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : secro.img [FL] : Set : logo.bin [FL] : Set : md1rom.img [FL] : Set : system.img [FL] : Set : userdata.img [FL] : Total size : 0x4817B657 [ 1.13 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] NAND: 98DE88A37251080000000000 NAND: TSIZE : 0x217800000 [ 8.37 GB ] ASIZE : 0x1F7400000 [ 7.86 GB ] PSIZE : 0x00004000 [ 16.00 KB ] BSIZE : 0x00600000 [ 6.00 MB ] SSIZE : 0x000007A0 STYPE : 0x0013 CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F059277169DA3CE18DAB319D5B8105BD DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Write : UBOOT Write : BOOTIMG Write : RECOVERY Write : SEC_RO Write : LOGO Write : MD1IMG Write : ANDROID Write : USRDATA [FL] : Flashing finished! Done! Elapsed: 00:07:15 READ NV Code: Operation : Read Security [ v2.00 r2 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM37) MODE : PRELOADER PORT PORT : 37 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] NAND: 98DE88A37251080000000000 NAND: TSIZE : 0x217800000 [ 8.37 GB ] ASIZE : 0x1F7400000 [ 7.86 GB ] PSIZE : 0x00004000 [ 16.00 KB ] BSIZE : 0x00600000 [ 6.00 MB ] SSIZE : 0x000007A0 STYPE : 0x0013 CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F059277169DA3CE18DAB319D5B8105BD DA : USB : HIGH-SPEED Boot done! SEC Data : IMEI[0] : 358748081846893 IMEI[1] : 358748081846901 NVRAM check : Passed! NVM saved as : MT6570__NAND__358748081846893.mt_sec NVM saved to : D:\Nv nd qcn China\NV\Dogee x10\ Done! Elapsed: 00:00:50 |
The Following 3 Users Say Thank You to -Mosin- For This Useful Post: |
05-21-2018, 14:01 | #3 (permalink) |
Member: 1948608 Status: Offline Thanks Meter: 1,744 | |
The Following User Says Thank You to -Mosin- For This Useful Post: |
05-21-2018, 17:45 | #4 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: algeria c Age: 42
Member: 683625 Status: Offline Thanks Meter: 72 | @mosin pls what da select i have this error Quote:
09-11-2018, 11:52 | #6 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | same erreur how to solved DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6570 EMI : SRC : preloader_jc45btlc.bin EMI : CNT : 0002 EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512,00 MB ] EMI : [01] : DRAM : EXTERNAL DRAM [LP/DDR2] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512,00 MB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
