05-29-2015, 17:26 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | ..:::<<<<World 1st Micromax Canvas XL2 A109 Read Factory File Done>>>>:::.. Code: Operation : Check / Read Info [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D56573549A601426B11D9C6 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D4201A649C6D9116B [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A109 ProdModel : Micromax A109 Device : A109 AndroidVer: 4.4.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.KK1.MP5.V1.5 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001154D56573549A601426B11D9C6 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D4201A649C6D9116B [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : A109 ProdModel : Micromax A109 Device : A109 AndroidVer: 4.4.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.KK1.MP5.V1.5 [Read Ok] : preloader_yulong89_wet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : autobak.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6589 / V1.0.0 / yulong89_wet_kk / EMMC FW Size : 940 MiB Scatter saved to : C:\Documents and Settings\Administrator\Desktop\MT6589__Micromax__Micromax A109__A109__4.4.2__ALPS.KK1.MP5.V1.5\ All done! Done! Elapsed: 00:05:06 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to pradeep_kus For This Useful Post: |
