09-18-2015, 16:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | World 1st Panasonic P55 Read Frimware N Write Fw Done :) Code: Chinese Miracle II [MTK module] v 1.30 Operation : Check / Read Info [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200CE409BEE620D DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMS27 [eMMC] : FLASH_CID : 150100513732534D4200CE409BEE620D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x292A4000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Panasonic ProdName : P55_Novo ProdModel : Panasonic P55 Novo Device : P55_Novo AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : S3569_DS35691_KARBONN_L113 MODEM : BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P20_1_wg_n EXTRA : LCD [0] : hx8394d_hd720_dsi_vdo_s35 LCD [1] : otm1287_hd720_dsi_vdo_boyi_s35 LCD Res : 1280x720 TOUCH [0] : GT915M_S35 CAM [0] : ov13850_mipi_raw_s35_sunwin CAM [1] : ov5670_mipi_raw_s35 CAM [2] : gc2355_mipi_raw_s35 MODEM : s3598_modem LOCALE : en_US en_GB hi_IN ja_JP fr_FR de_DE it_IT ru_RU zh_CN ar_IL bn_IN th_TH af_ZA ar_IL zh_TW en_IN tl_PH in_ID fa_IR pt_PT es_ES sw_TZ ur_PK vi_VN zu_ZA nl_BE nl_NL pl_PL tr_TR uk_UA gu_IN mr_IN pa_IN Done! Elapsed: 00:00:13 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200CE409BEE620D DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMS27 [eMMC] : FLASH_CID : 150100513732534D4200CE409BEE620D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x2946C000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200D0E3C6F852B7 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMS27 [eMMC] : FLASH_CID : 150100513732534D4200D0E3C6F852B7 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Panasonic ProdName : P55_Novo ProdModel : Panasonic P55 Novo Device : P55_Novo AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : S3569_DS35691_KARBONN_L109 MODEM : BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P20_1_wg_n EXTRA : LCD [0] : hx8394d_hd720_dsi_vdo_s35 LCD [1] : otm1287_hd720_dsi_vdo_boyi_s35 LCD Res : 1280x720 TOUCH [0] : GT915M_S35 CAM [0] : ov13850_mipi_raw_s35_sunwin CAM [1] : ov5670_mipi_raw_s35 CAM [2] : gc2355_mipi_raw_s35 MODEM : s3598_modem LOCALE : en_US en_GB hi_IN ja_JP fr_FR de_DE it_IT ru_RU zh_CN ar_IL bn_IN th_TH af_ZA ar_IL zh_TW en_IN tl_PH in_ID fa_IR pt_PT es_ES sw_TZ ur_PK vi_VN zu_ZA nl_BE nl_NL pl_PL tr_TR uk_UA gu_IN mr_IN pa_IN Done! Elapsed: 00:00:13 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.30 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200D0E3C6F852B7 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMS27 [eMMC] : FLASH_CID : 150100513732534D4200D0E3C6F852B7 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Panasonic ProdName : P55_Novo ProdModel : Panasonic P55 Novo Device : P55_Novo AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : S3569_DS35691_KARBONN_L109 [Read Ok] : preloader_s3569.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : test.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6592 / V1.1.2 / s3569 / EMMC FW Size : 1192 MiB Scatter saved to : C:\Documents and Settings\Administrator\Desktop\A35k latest sw\MT6592__Panasonic__Panasonic P55 Novo__P55_Novo__4.4.2__S3569_DS35691_KARBONN_L109\ All done! Done! Elapsed: 00:05:38 Reconnect Power/Cable! Now Writing Fw - to Faulty Set Code: Scatter Load Ok , BaseBand : MT6592 , Project : s3569 , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.30 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200CE409BEE620D DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMS27 [eMMC] : FLASH_CID : 150100513732534D4200CE409BEE620D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x286AC000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : s3569 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x00000001CEE00000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s3569.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : TEST Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:36 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : TEST Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:34 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:35 Reconnect Power/Cable! |
The Following 7 Users Say Thank You to pradeep_kus For This Useful Post: |
09-18-2015, 17:49 | #2 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, This Mean MTKxPRJ : S3569_DS35691_KARBONN_L113 Karbonn Have Same Model But Which One ?. |
The Following User Says Thank You to MyGSM World For This Useful Post: |
09-19-2015, 15:13 | #5 (permalink) | ||
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
yes bro but i don't know Quote:
http://forum.gsmhosting.com/vbb/11207761-post2.html http://forum.gsmhosting.com/vbb/11207761-post2.html | ||
The Following 2 Users Say Thank You to pradeep_kus For This Useful Post: |
02-12-2016, 08:10 | #9 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
http://forum.gsmhosting.com/vbb/11495400-post18.html here ur answer check it | |
04-30-2017, 12:32 | #10 (permalink) | |
Insane Poster Join Date: Jun 2012 Location: vasai, mumbai,india
Member: 1768108 Status: Offline Sonork: [email protected] Thanks Meter: 15 | mtk best tool Quote:
every box if u think purchase any tool so i think ...Infinity... is best in world Last edited by YellowBoss; 04-30-2017 at 13:09. Reason: Wrong product name fixed | |
04-30-2017, 12:33 | #11 (permalink) |
Member: 1768108 Status: Offline Sonork: [email protected] Thanks Meter: 15 | Use ...Infinity... box veery good tool for every module Last edited by YellowBoss; 04-30-2017 at 13:09. Reason: Wrong product name fixed |
