01-01-2016, 16:30 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | [World First] Alcatel "Pixi First" SC7731 : Repair/FW/Service/Forensic! Code: SLDR Load Ok BB CPU : SC7731 SC7731 Alcatel For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.10 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Alcatel eMMC Loader Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : ALCATEL_ONETOUCH_4024D Model Brand : TCL Model Device: ALCATEL_ONETOUCH_4024D AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA_18045 CompileDate : 1442825396 Project Ver : 4024D_RU_AL_V1.8_150921 Model Ext : 4024D ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:13 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.10 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Alcatel eMMC Loader Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Write new security data : IMEI1 : 999923232323234 IMEI2 : 999945445454548 Step #1 Ok Step #2 Ok Step #3 Ok Write done! Elapsed: 00:00:18 Reconnect Power/Cable! Just REAL, FULL , COMPLETE and WORKING firmware, which allow revive phones from ANY state Code: Operation : Read FullFlash [ v1.10 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Alcatel eMMC Loader Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Alcatel eMMC Loader Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : ALCATEL_ONETOUCH_4024D Model Brand : TCL Model Device: ALCATEL_ONETOUCH_4024D AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA_18045 Project Ver : 4024D_RU_AL_V1.8_150921 Model Ext : 4024D [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem.bin [Read Ok] : sc7731g_modem_CP2_WCN_14E_W15.31.1_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 1242 MiB Saved to : E:\SP7731GEA_18045_ALCATEL_ONETOUCH_4024D_4.4.2_4024D_RU_AL_V1.8_150921\ Done! Elapsed: 00:11:00 Reconnect Power/Cable! 3 Minutes for get a result Code: Infinity SC Firmware Detected FW Size : 1242 MiB Load Ok! Operation : Flash [ v1.10 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Alcatel eMMC Loader Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_modem_CP2_WCN_14E_W15.31.1_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_480x800.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x800.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Erase Block : INTERNALSD Erase block ... Block erase Ok! Elapsed: 00:02:58 Reconnect Power/Cable! 12 seconds for whole process from press button to get result. Code: Operation : Read PatternLock [ v1.10 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Alcatel eMMC Loader Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 124789 Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: Operation : Read PhoneBook [ v1.10 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Alcatel eMMC Loader Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Mount : /data Size : 0x000000005DBFB000 Step #1 Step #2 Read Ok, PhoneBook records extracted : 6 TXT Saved to : C:\InfinityBox\CM2SPD\phdata\SPD_Pixi_PhoneBook.txt Write : 6 CSV Saved to : C:\InfinityBox\CM2SPD\phdata\SPD_Pixi_PhoneBook.csv Write : 6 VCF Saved to : C:\InfinityBox\CM2SPD\phdata\SPD_Pixi_PhoneBook.vcf Write : 6 VCFv3 Saved to : C:\InfinityBox\CM2SPD\phdata\SPD_Pixi_PhoneBook_v3.vcf Elapsed: 00:00:20 Reconnect Power/Cable! Code: Operation : Format File System [ v1.10 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 35 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Alcatel eMMC Loader Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000005DBFB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following 22 Users Say Thank You to JayDi For This Useful Post: |
03-07-2016, 16:59 | #3 (permalink) | |
Freak Poster Join Date: Feb 2011 Location: moon Age: 37
Member: 1523083 Status: Offline Sonork: 100.1609029 Thanks Meter: 141 | goood work alcatel 4024d read pattern Quote:
The Following User Says Thank You to cavalierks For This Useful Post: |
04-25-2016, 11:46 | #12 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Unlock network Unlock from network TELE2 KZ Code: Chinese Miracle II [SPD module] v 1.16 Start at : [25.04.2016 / 16:22:24] Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 155 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : ALCATEL_ONETOUCH_4024D Model Brand : TCL Model Device: PLAY_P1 AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA_18045 CompileDate : 01.10.2015 9:28:31 Project Ver : 4024D_KZ_AL_V1.2_151001 Model Ext : 4024D ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:24 Reconnect Power/Cable! Finish at : [25.04.2016 / 16:22:49] Start at : [25.04.2016 / 16:23:49] Operation : SP Unlock [ v1.16 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 155 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Locked! Unlocking ... Unlock Done! Elapsed: 00:00:16 Reconnect Power/Cable! Finish at : [25.04.2016 / 16:24:06] |
The Following User Says Thank You to Abzal For This Useful Post: |
05-15-2016, 13:02 | #15 (permalink) | |
Freak Poster Join Date: Apr 2012 Location: World Age: 37
Member: 1753151 Status: Offline Sonork: 100.1658597 Thanks Meter: 332 | Quote:
We really need. | |
