08-15-2018, 16:00 | #1 (permalink) |
Freak Poster Join Date: Nov 2017
Member: 2775355 Status: Offline Thanks Meter: 177 | World First Infinix x608 Reset Password/Frp Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 73038C36 ID_BLOCK_L : B3B52FD786EC1914F3A8A8B572C94981 ID_BLOCK_L : DEB51BB2A72E9015A807488183627C5F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE63MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to KSJphoneFastFix For This Useful Post: |
08-16-2018, 23:20 | #3 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | Not a World First, was done before, I did a few with Infinity Dongle a month ago. Check Here for EDL Mode. Good Luck |
The Following User Says Thank You to PhoneCareCenter For This Useful Post: |
08-17-2018, 16:00 | #4 (permalink) |
Insane Poster Join Date: Aug 2014
Member: 2240998 Status: Offline Thanks Meter: 27 | Infinix x608 phone off. Please help!!! AFTER A SUCCESSFUL OPERATION ON INFINIX X608, THE PHONE IS REFUSING TO ON. PLEASE HELP!!!! FRP LOGS Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : D75E2BBE ID_BLOCK_L : CB3D57AF0E94818C7BD0202DEAB1C109 ID_BLOCK_L : 3548F6595AC575FE13E2B76C6689A7A4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE63MB Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:32 READ INFO LOGS Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : D75E2BBE ID_BLOCK_L : CB3D57AF0E94818C7BD0202DEAB1C109 ID_BLOCK_L : 3548F6595AC575FE13E2B76C6689A7A4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE63MB Boot Ok! Brand : Infinix ProdName : QL1661 ProdModel : Infinix X608 Device : Infinix-X608 AndroidVer: 8.0.0 Manufact. : INFINIX MOBILITY LIMITED SysPatch : OPR1.170623.032 DevComTime: 7/23/2018 6:56:30 AM QLMxPRJ : X608-QL1661ABCDEF-O-180720V19 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:30 WHAT SHALL I DO TO REVIVE THIS PHONE? PLEASE HELP!!! |
08-17-2018, 16:46 | #5 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
Try reset setting full ( Format + frp ) Check result. | |
08-17-2018, 18:08 | #6 (permalink) |
Registered User Join Date: Jul 2008 Location: Elmounfua
Member: 807683 Status: Offline Thanks Meter: 86 | Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 425 [MSM8917] ID_BLOCK_S : 2FB43463 ID_BLOCK_I : 000560E1 ID_BLOCK_L : 6080FA04B33F242700759F804F1A9AB2 ID_BLOCK_L : 6FE6A803F49FCF4479B419D6DCD3CD0E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GD6BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:08 |
08-17-2018, 18:26 | #7 (permalink) |
Member: 2240998 Status: Offline Thanks Meter: 27 | DONE BUT NO LUCK FOR ME AS PHONE IS STILL OFF. HERE: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : D75E2BBE ID_BLOCK_L : CB3D57AF0E94818C7BD0202DEAB1C109 ID_BLOCK_L : 3548F6595AC575FE13E2B76C6689A7A4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE63MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! |
08-17-2018, 18:31 | #8 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
09-05-2018, 12:00 | #9 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 79 | Very Cool, Thanks to Infinity-Box Team Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 425 [MSM8917] ID_BLOCK_S : 8EBC1E96 ID_BLOCK_I : 000560E1 ID_BLOCK_L : 13D58F77E64C79745308C8D51269E9E1 ID_BLOCK_L : 97EE50FBFC67D75C71BC11CEC42BC506 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE63MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
The Following User Says Thank You to madcom5 For This Useful Post: |
10-04-2018, 12:45 | #10 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1893304 Status: Offline Thanks Meter: 0 | just simply press and hold space bar on x608 keyboard, choose touchpal keyboard.... follow thesame procedure of techno device with quick shortcut maker, search oobe tap... successfully bypassed... Last edited by mihut; 06-17-2019 at 12:53. |
10-06-2018, 10:25 | #11 (permalink) | |
Freak Poster Join Date: Jul 2016 Location: phillipines
Member: 2596094 Status: Offline Thanks Meter: 83 | Quote:
this tread is infinity bro | |
The Following User Says Thank You to chezzter For This Useful Post: |
06-17-2019, 12:32 | #15 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | Quote:
regards | |
