06-30-2015, 15:11 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | <<<World First Intex Aqua V 3G SPD7715 Read Patternlock Done by Great Infinity CM2>>> Intex Aqua V 3G Readinfo Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 paniSync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 2204ESending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : NAND Flash , Structure : Ok! Raed Patternlock Done Code: Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 COM*Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 2204ESending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 12357 Done! Elapsed: 00:07:10 Reconnect Power/Cable! Also Format Done Code: Operation : Format File System [ v1.02 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 COMlSync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 2204ESending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to ishant For This Useful Post: |
07-01-2015, 07:16 | #2 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | Intex Aqua V2 APP Run Error Done just Format With Infinity CM2 Readinfo Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : NAND Flash , Structure : Ok! Elapsed: 00:00:23 Reconnect Power/Cable! Code: Operation : Format File System [ v1.02 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to ishant For This Useful Post: |
07-08-2015, 23:28 | #3 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Kisangani, CONGO D R
Member: 211318 Status: Offline Thanks Meter: 58 | Operation : Format File System [ v1.02 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 508 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/SC7731 loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Format disabled for eMMC for now! Done! Elapsed: 00:01:00 Reconnect Power/Cable! |
07-09-2015, 04:08 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Exactly, eMMC format NOT enabled. Wait for next week. Will be new update with eMMC format support and more things. |
07-20-2015, 06:54 | #5 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | Aqua 3G+ Read Patternlock Done Code: Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 OM7 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 lock Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 159683724 Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
07-24-2015, 13:21 | #7 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | Another World First Intex Aqua 3G PRO Read Patternlock Done Read Info Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Û>°Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 12E30Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Aqua_3G_Pro Model Brand : Intex Model Device: Aqua_3G_Pro AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715EA CompileDate : 1431748457 Project Ver : Intex_Aqua_3G_Pro_V08_Indian Model Ext : Aqua 3G Pro Read Patternlock Done Code: Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 32145879 Done! Elapsed: 00:00:18 |
