04-18-2016, 18:49 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | World First LG-H502F Read info/Read Factory Flash/Read NVMRAM Done Read Info Done Code: Operation : Check / Read Info [ v1.46 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200E79CD22CA2CD Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200E79CD22CA2CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 697186BE85C2BBA7D2BFBC9A6DC45BA3 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : my90ds_global_com ProdModel : LG-H502 Device : my90ds AndroidVer: 5.0.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP1.TC1SP.V1.4_MUSE6582.Y90.L_TMP2 Done! Elapsed: 00:00:20 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.46 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200E79CD22CA2CD Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200E79CD22CA2CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 697186BE85C2BBA7D2BFBC9A6DC45BA3 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6582_S00_MOLY_WR8_W1338_MD_WG_TC01_MUSE82Y_SP_V1_P7_1_wg_n NVM Read Ok, MT6582_S00_MOLY_WR8_W1338_MD_WG_TC01_MUSE82Y_SP_V1_P7_1_wg_n_eMMC.spnv SEC Read Ok, LG-H502f_CY14S151101000185.lgsec Done! Elapsed: 00:00:42 Reconnect Power/Cable! Read Factory Flash Done Code: Operation : Read Flash [ v1.46 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200E79CD22CA2CD Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200E79CD22CA2CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 697186BE85C2BBA7D2BFBC9A6DC45BA3 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : lge ProdName : my90ds_global_com ProdModel : LG-H502 Device : my90ds AndroidVer: 5.0.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP1.TC1SP.V1.4_MUSE6582.Y90.L_TMP2 [Read Ok] : preloader_muse6582_y90_l.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : ubootbak.bin [Read Ok] : laf.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : EBR3 [Read Ok] : persist.img [Read Ok] : cust.img [Read Ok] : factory.img [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / muse6582_y90_l / EMMC Android Info saved FW Size : 2718 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__lge__LG-H502__my90ds__5.0.1__ALPS.L0.MP1.TC1SP.V1.4_MUSE6582.Y90.L_TMP2\ All done! Done! Elapsed: 00:12:02 Reconnect Power/Cable! |
05-17-2016, 14:05 | #3 (permalink) |
Freak Poster Join Date: Nov 2012 Location: batna.algeria
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | Code: Operation : Read Flash [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 88 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420024BE9A4CC291 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420024BE9A4CC291 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : B0176DB7497371C1C1959B3C0A89B40D INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : lge ProdName : my90ds_global_com ProdModel : LG-H502 Device : my90ds AndroidVer: 5.0.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP1.TC1SP.V1.4_MUSE6582.Y90.L_TMP2 [Read Ok] : preloader_muse6582_y90_l.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : ubootbak.bin [Read Ok] : laf.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : EBR3 [Read Ok] : persist.img [Read Ok] : cust.img [Read Ok] : factory.img [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / muse6582_y90_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2719 MiB Scatter saved to : I:\lg mtk\MT6582__lge__LG-H502__my90ds__5.0.1__ALPS.L0.MP1.TC1SP.V1.4_MUSE6582.Y90.L_TMP2\ All done! |
01-02-2017, 12:45 | #4 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: wazirabad gujranwala pakistan Age: 30
Member: 2158722 Status: Offline Sonork: 1668812 Thanks Meter: 39 | bro have you lg k 410 firmware ProdModel : LG-K410 i need Quote:
Brand : lge ProdName : m23g_global_com ProdModel : LG-K410 Device : m23g AndroidVer: 5.0.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP1.TC1SP.V1.4_MUSE6582.Y90.L_TMP2 here is my log | |
