04-06-2016, 11:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Algeria Age: 40
Member: 1501852 Status: Offline Thanks Meter: 132 | World First Polaroid MID4X10PJ MT8127 Factory File Read & Remove Monkey Test by Infin World First Polaroid MID4X10PJ MT8127 Factory File Read & Remove Monkey Test By Infinity-Box All Other Tool Field To remove Monkey Virus But The Only One Great Infinity-Box (c) Chinese Miracle II Remove Viruses [SmartAV] Code: Start at : [03-04-2016 / 15:46:03] Operation : Remove Viruses [SmartAV] [ v1.44 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : NOT INSTALLED eMMC Flash : 8801034E4361726420202C5216578141 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E4361726420202C5216578141 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x000000039D000000 [eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB] DEV RID : C65C9B7A3BD9EB4CC8D13A302F393445 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 38 Removing infected files and scripts ... SmartAV Report : Removed 38 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:01:15 Reconnect Power/Cable! Finish at : [03-04-2016 / 15:47:19] Read Flash Code: Start at : [03-04-2016 / 15:39:41] Operation : Read Flash [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Start at : [03-04-2016 / 15:39:59] Operation : Read Flash [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : NOT INSTALLED eMMC Flash : 8801034E4361726420202C5216578141 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E4361726420202C5216578141 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x000000039D000000 [eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB] DEV RID : C65C9B7A3BD9EB4CC8D13A302F393445 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : MID4X10PJ ProdName : MID4X10PJ ProdModel : MID4X10PJ Device : MID4X10PJ AndroidVer: 4.4.2 MTKxCPU : MT8127 MTKxPRJ : MID4X10PJ_2014-09-24 [Read Ok] : preloader_mid4x10pj.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT8127 / V1.1.2 / mid4x10pj / EMMC Android Info saved HWConfig Info saved FW Size : 950 MiB Scatter saved to : C:\Users\Bekhiti_Info\Desktop\MT8127__MID4X10PJ__MID4X10PJ__MID4X10PJ__4.4.2__MID4X10PJ_2014-09-24\ All done! Done! Elapsed: 00:05:23 Reconnect Power/Cable! Finish at : [03-04-2016 / 15:45:23] |
The Following User Says Thank You to bek4ever For This Useful Post: |
02-07-2017, 20:30 | #2 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: algerie
Member: 259512 Status: Offline Thanks Meter: 33 | please can u upload this firmware i need it thanks Quote:
The Following User Says Thank You to msitfa For This Useful Post: |
