01-10-2017, 16:58 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Faisalabad Pakistan
Member: 696491 Status: Offline Thanks Meter: 164 | World first qmobile i2 pro read file I HAVE DONE RESET FORMATE FRP OPERATION 100% SAFE LOG FILE IS AS UNDER: Infinity SC Firmware Detected FW Size : 2318 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : i2_PRO Device CPU : i2 PRO Device IntName : i2_PRO Device Version : 5.1 Device Compile : 11/14/2016 5:51:51 AM Device Project : QMobile_i2_PRO_MP_09_11 Device ExtInfo : QMobile i2 PRO Operation : Read NV [ v1.22 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0x00029670 Saved to : C:\Users\XXXXX\Desktop\Read Out\I2_PRO_i2_PRO_5.1_QMobile_i2_PRO_MP_09_11_QMob ile_i2_PRO\CX_SPDNV_i2 pro.spdnv Elapsed: 00:00:29 Reconnect Power/Cable! Operation : Convert InfinitySC to SPRD PAC [ v1.22 ] Target : I2_PRO_i2_PRO_5.1_QMobile_i2_PRO_MP_09_11_QMobile_ i2_PRO Step #1 : Identify MEMORY : eMMC LAYOUT : eMMC NORMAL Step #2 : Select logic Select Logic : SC7731 Step #3 : Processing data Build PAC [ADD FILE] : nvitem_w.bin [ADD FILE] : nvitem_wcn.bin [ADD FILE] : prodnv.img [ADD FILE] : u-boot-spl-16k.bin [ADD FILE] : sc7731g_CP0_modem.bin [ADD FILE] : DSP_DM_Gx.bin [ADD FILE] : sc8830g_modem_CP2_WCN_14D_W15.43.3_Release.bin [ADD FILE] : logo_480x854.bin [ADD FILE] : fblogo_480x854.bin [ADD FILE] : boot.img [ADD FILE] : system.img [ADD FILE] : cache.img [ADD FILE] : recovery.img [ADD FILE] : userdata.img [ADD FILE] : u-boot.bin Build Ok! Result : 0x0017 Sign PAC ... Sign Ok! FW compiled! Elapsed: 00:01:17 Saved to : I2_PRO_i2_PRO_5.1_QMobile_i2_PRO_MP_09_11_QMobile_ i2_PRO.pac Done! |
The Following User Says Thank You to netvision123 For This Useful Post: |
01-10-2017, 22:24 | #2 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | the Question is that you loaded .pac file before any opration where to come that .pac file ? can you share i2 pro .pax file read by CM2 thanks |
01-11-2017, 05:39 | #3 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | Last day i also receive same model with pattern lock problem. but not able to remove any opreation with cm2 like read flash . format or read patren . now i see u use pac file as loder . how u can read that? |
07-30-2017, 10:49 | #5 (permalink) |
Freak Poster Join Date: Jul 2011 Location: gilgit city pakistan
Member: 1615377 Status: Offline Sonork: forever,s Thanks Meter: 14 | here is OK and tested flash file link. https://mobiappsbank.********.com/20...c7731-pac.html |
