10-18-2007, 10:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | World Tel A828 Error Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#2/1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 4 sec Remove/Install battery now ! WHEN FORMAT FFS IT SHOW COM6 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 error: boot phase#2/2 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom serious damaged, use repair eeprom files or use other unlock/format method Operation failed ! Finished, time used: 9 sec Remove/Install battery now ! IS IT A CABLE PROBLEM OR HARDWARE |
10-18-2007, 12:35 | #3 (permalink) | |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
I HAVE TRIED IT IN ONE ANOTHER BOX THE CABLE IS CONNECTING THE BOX AND THE SET BUT THE BOX DON'T SUPPORT THIS MOBILE. | |
Marvelous Spectacle of the World -- Huangguoshu Waterfall (???????) (box packing VCD) | IPMART | ipmart WebShop | 0 | 03-29-2010 14:00 |
Awang-A828 need flash file | kasim | Infinity-Box | 1 | 03-06-2008 12:22 |
