09-05-2015, 10:34 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | WorldFirst : Alcatel OneTouch Pixi3(4.5) on MT6735 - Direct Unlock! Code: Operation : Check / Read Info [ v1.29 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154D533237A52C0042A11C70D0 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMS27 [eMMC] : FLASH_CID : 150100513732534D42002CA5D07062A1 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TCL ProdName : 5017X ProdModel : 5017X Device : PIXI3_45_4G AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V1_JHZ6735M.35U.L_P69 Done! Elapsed: 00:00:24 Reconnect Power/Cable! Direct Unlock : Code: Operation : SP Unlock [ v1.29 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154D533237A52C0042A11C70D0 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMS27 [eMMC] : FLASH_CID : 150100513732534D42002CA5D07062A1 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Lock Status : Locked! Unlocking ... Unlock done! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
The Following 17 Users Say Thank You to JayDi For This Useful Post: |
09-07-2015, 09:41 | #2 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | jaydi how do you unlock[read codes or direct} mtk phones.,,i can read info ..reset pattern,,,format etc. bt my simlock tab isnt active,,,is it via adb or... |
09-07-2015, 09:50 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Settings -> SP : Select Model [MT6571-MT6795] Then select desired method - model list or Generic "Read Codes" or "Direct Unlock" method. |
