Old 05-05-2015, 16:17   #1 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
[WorldFirst] MediaTek MT6732 ( 64Bit 4G ) Direct Unlock!
Take a phone and insert SimCard :
Open CM2 and select MT67xx Generic or Model ( im my case it is ZTE Blade Q ) , press "SP Unlock".
24 seconds for connect and waiting :
And the result :
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 05-06-2015, 13:19   #2 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 730
mm... good but only need to CM2MTK 1.19 to be released to public....
Old 05-06-2015, 13:22   #3 (permalink)
JayDi's Avatar
Member: 462970
It will be in near hours. I just want finish and fix MT6582 flashing problems.
Old 08-21-2015, 05:09   #4 (permalink)
Member: 574542
Thanks Meter: 15
Hi, i have zte blade q lux....sp unlock press after no find phone
my phone not detecting MTK to computer.......
i install InfinityBox_update_CM2MTK_Drivers_v1.00
still no connection pls help me.....
Old 08-21-2015, 05:09   #5 (permalink)
Member: 574542
Thanks Meter: 15
Old 08-21-2015, 05:20   #6 (permalink)
JayDi's Avatar
Member: 462970
Hello.
Connect powered off phone, without holding side keys. It will work.
Does PC detect anything, when you connect?
Old 08-21-2015, 05:25   #7 (permalink)
Member: 574542
Thanks Meter: 15
no....pc detect nothing
Chinese Miracle II [MTK module] v 1.25
Operation : SP Unlock [ v1.25 ]
Mode : Direct Unlock
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:29
Reconnect Power/Cable!
Old 08-21-2015, 05:55   #8 (permalink)
Member: 574542
Thanks Meter: 15
ZTE feature phone - Telstra 4GX Buzz - ZTE Blade Q Lux
my model is this one....please help me to unlock
Old 08-21-2015, 06:13   #9 (permalink)
JayDi's Avatar
Member: 462970
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:29
It should be detected. Until PC not find phone - there is no reason asking "how unlock".
Try insert cable in phone without battery, then fastly insert battery.
Old 08-21-2015, 07:31   #10 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:29
monitor connection open device manage and then connect the phone can be driver issue. see if there any port show or unknown device.
wBw,
Nasir Javed
Old 09-03-2015, 06:06   #11 (permalink)
Member: 2038267
wBw,
Nasir Javed
i have same telstra zte blade q lux phone same problem not connecting. if there is any special driver pls give me link.
Old 09-03-2015, 06:10   #12 (permalink)
Member: 574542
Thanks Meter: 15
wBw,
Nasir Javed
Hi sir,
I try this with different pc and I have 5 phone all same issue . I can't unlock pls pls help
Old 09-03-2015, 06:17   #13 (permalink)
Member: 2038267
Hi,
help me pls.........................................
Old 09-03-2015, 11:17   #14 (permalink)
JayDi's Avatar
Member: 462970
All explained. If can't connect phone to PC - that not a SW problem.
Page generated in 0.22383 seconds with 8 queries
