11-26-2015, 20:04 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | [WorldFirst] SC7731 Android 5.x FRP remove! Code: Operation : Format File System [ v1.07 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 71 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Reset FRP Lock Reset Ok! Mount : /data Size : 0x0000000160DF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
09-19-2016, 20:20 | #2 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Maroc
Member: 166142 Status: Offline Thanks Meter: 20 | Hardware:sc7731c Board:sp7731cea CPU ABI:armeabi-v7a Manufacturer:xtouch Model:e2 Android Ver:5.1 bootloader ver:unknown USB config:mtp,adb User:jks Baseband ver:tm_base_15b_w16.09.4|sc7731g_cp0_modem|02-24-2016 17:56:34 Build number:e2-5.1-tecsync-20160621-v1 ID:lmy47d Region:us Language:en Chipset:sc8830 boot failed ver 1.21 |
09-20-2016, 23:23 | #5 (permalink) |
Member: 166142 Status: Offline Thanks Meter: 20 | Phone found! [ 71 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable boot failed FDL Ready! |
10-17-2016, 15:04 | #6 (permalink) | |
No Life Poster Join Date: Aug 2008 Location: Spain
Member: 840762 Status: Offline Thanks Meter: 166 | Archos 45B NEON - Android 5.0.1- F.R.P. Done! 1. Open Cm2spd v1.21 tool 2. Set CPU "SC7730 SC7731 EMMC Android5.x" 3. Set "Alternative LDR Mode" 4. Go to "Service" Tab, and pick in "CLEAR FRP" 5. The battery is unremovable in this phone, only shut down phone, press vol-+ and connect usb cable: Quote:
The Following User Says Thank You to NEOCRIVI For This Useful Post: |
03-06-2017, 12:15 | #8 (permalink) |
No Life Poster Join Date: Mar 2007 Location: PL Age: 44
Member: 477842 Status: Offline Thanks Meter: 80 | I Install Spreadtrum drivers from infinity support use windows xp , windows vista, but no solution to reset frp in archos 45b, stil MTP drivers problem , and program dont find this phone how to solve this ? |
