Old 11-03-2016, 10:02   #1 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 617
World's 1st Qmobile Z8 Qualcomm SnapDragon 410 [MSM8916] Read Pattern Lock Done
Operation : Identify [ v1.01 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 13C4E597
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 49C762F6FE52E492
ID_BLOCK_L : 9B939302A85331CC
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1
ExtInfo : 0x00004000/00004000/00001000/00001000
Boot Ok!
Brand     : QMobile Z8
ProdName  : QMobile Z8
ProdModel : QMobile Z8
Device    : l5510
AndroidVer: 5.0.2
Manufact. : QMobile Z8
QLMxCPU   : MSM8916
Done!
Elapsed: 00:00:36
Reconnect Power/Cable!
Operation : Read PatternLock [ v1.01 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 45632
Done!
Elapsed: 00:00:41
Old 11-03-2016, 10:05   #2 (permalink)
scorpian1982's Avatar
Member: 2192793
Thanks Meter: 170
can you plz explain how to connect Z8 with CM2QLM???????
Old 11-03-2016, 10:27   #3 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 617
1 install Emergency Mode Drivers Download From Infinity Support Named
InfinityBox_update_CM2QLM_Drivers_v1.00.7z
2 after download and install open path/directory C:\InfinityBox\CM2QLM\Drivers
3 install EmergencyDownloadDriver.exe
4 open cm2 qualcomm exe and do select and run which operation you want to do
5 power off mobile pres volume up and down @ same time and insert usb cable
Hope It's Clear
The Following User Says Thank You to Luckey1 For This Useful Post:
Old 11-03-2016, 17:05   #4 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 551
here an other report ,,,,,,,,,,,,,,,,,,
Card found : S/N : 2C4288A9 , v0134
Infinity-Box Qualcomm Module [QLM] v 1.01
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 0448EB10
Boot Ok!
PatternLock sequence : 3478
Done!
Elapsed: 00:00:22
Old 11-03-2016, 17:14   #5 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 551
after installing drivers go to setting and select "Force to int.LDR" then press service butoon and press "Read PatternLock"........connect phone while pressing both volum keys
Old 12-20-2016, 08:05   #6 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
wiko rainbow jam 4g read pattern done
Operation : Read PatternLock [ v1.04 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8909]
ID_BLOCK_S : 0030502C
ID_BLOCK_I : 009600E1
ID_BLOCK_L : 5BF3348E79C777DF
ID_BLOCK_L : C060A78CD1944613
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x0000C000/00100000/00001000/00001000
Boot Ok!
PatternLock sequence : 15963
Done!
Elapsed: 00:00:18
Old 12-20-2016, 10:22   #7 (permalink)
Member: 894224
Thanks Meter: 86
vivio 21l have failed to read pattern am not luck never read any qualcomm phone with infinity dongle
Old 12-20-2016, 15:49   #8 (permalink)
Member: 2195211
Thanks Meter: 4,294,967,295
first check if it is fully supported or not?
Old 12-20-2016, 16:15   #9 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,958
Hope It's Clear
Very very clear, but I try it phone boot to fastboot mode immediately
Old 12-20-2016, 16:19   #10 (permalink)
Member: 1677653
Thanks Meter: 1,958
Can u please post screenshot step by step?
Old 12-20-2016, 16:40   #11 (permalink)
Member: 1677653
Thanks Meter: 1,958
I cannot find anything like FORCE TO INT.LDR
SEE SCREENSHOT
Old 12-20-2016, 18:10   #12 (permalink)
Member: 148515
Thanks Meter: 15,716
v1.05 was just for test but not for public use.
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Page generated in 0.31151 seconds with 7 queries
