06-29-2015, 17:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Wow Hoooooooooooooo......... Datawind Pocketsurfer3G4 Hang @ Blue Screen Factory Firmware Searched But No One Have No Chinese Box Support It But Infinity CM2SPD Done It In A Few Second Check/Read Info Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 188 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : NAND Flash , Structure : Ok! Elapsed: 00:00:13 Code: Operation : Format File System [ v1.02 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 188 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to VIJAY2U2 For This Useful Post: |
06-29-2015, 18:04 | #2 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Datawind Pocketsurfer3G4 Datawind Pocketsurfer3G4 Read PatternLock Done For Test Code: Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 188 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 452369 Done! Elapsed: 00:04:41 Reconnect Power/Cable! |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
06-29-2015, 18:08 | #3 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Datawind Pocketsurfer3G4 Datawind Pocketsurfer3G4 IMEI Repair Done For Test Code: Operation : Repair Security [ v1.02 ] 1. Remove battery. Insert battery back 2. Insert cable ==== Wait for phone... Phone found! [ 179 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14A_W14.41_Debug Project : sc7715_modem HWInfo : sc7715_sc7715_modem Compile : 10-10-2014 10:49:18 Phone Security Info : IMEI [1] : 911413100328*** IMEI [2] : 911413100328*** BT_ADDR : 000000000000 Read Ok! Write new security data : IMEI1 : 000000000000000 IMEI2 : 000000000000000 Write done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to VIJAY2U2 For This Useful Post: |
