Member: 1527968
Sonork: 100.1651182 Thanks Meter: 483 | yes its tru.............. Quote:
=== v1.43 ===
Nokia 230 support and more
- Main
Nokia 230 (RM-1172, RM-1173) supported for "Identify", "Format FS" operations
Nokia MTK FlashLoaders updated
- Service
Improved Security Info reading for old devices
- Factory FW read improved
Brand-specific improvements
New types supported
- UserData
Safe PrivacyLock reset improved
"DataProtection" lock read improved ( 5.x.x )
- Other
ADB and FastBoot layer updated
NAND "Phone Info" read improved
AppManager DB updated ( +50 new records )
Flash ID database updated
Some other bugfixes and improvements
=== v1.42 ===
General improvements and fixes
- Main
FlashEngine Updated
AFF Verify operation improved
Some other changes and improvements
- Service operations improved
"Format FS" feature revised for old MT6575/MT6577 phones - Encryption and other problems
Format FS: Clear UDA+Cache (second option) method changed to WIPE
OTP detection improved
Security info read improved for MT6589 and MT6575/MT6577
Security Repair improved
FixDl operation support MT6589, especially for some Lenovo-like phones
NVRAM operations revised, NVRAM verify improved
FastBoot mode operations improved
Fix Unknown BaseBand revised: improved MT67xx support, new "deep fix" level supported
- Smart AV operations revised
"AppScanner" updated - Dictionary DB also updated +200 new types
- FW Read Engine Revised
Improved AutoDetection
Brand-Specific improvements - latest HTC, Infocus and other brands
NAND Factory FW reading improved
Additional files read improved
- UserData operations improved
DataDirect Engine revised
Secure Platforms supported improved
- Other
DRAM init revised for older platforms
All rest problems, reported by users has been fixed
Other different changes and improvements
FP platform Factory FW reading improved
=== v1.41 ===
New way MTK Servicing - Unlock/Security/Repair/Smart-AV/Service/UserData and more
- Main
Core completely revised
Improved all sub systems: Flash Engine, Read/Write and rest operations
SecureBoot Support revised
Support for MT6582 with GPT - under test
Dead/Erased flashing for MT6795 and MT6580 revised
BromInit fixed - Qmobile and some devices with "Init Not Done" problem
Initial boot procedure revised and improved
Latest FlashLoader package supported (v1552)
MT6573 support revised (moved on new loader)
"Read Security Info" option released. Allow read and check Security info (Identify) for NAND/eMMC
- Read phone IMEIs, BTMAC and WIFIMAC
- Detect "OTP" protected phones (like Alcatel and same)
Unique feature: "Read Full Info" option now allow read FULL NAND Info!
- Allow read full phone info - mode, version, build etc.
"HW Test" feature improved: MT6575/MT6577 specific improvements
Alcatel "ProInfo" operations improved
Alcatel "Repair FS" feature released
- Allow repair "stuck" problems after full erase/reflash
NVRAM operations revised - Normal and Secured mode
"Create BPLGUI" feature create MODEM CONFIG file (Maui Meta modem configuration) from ALL MTK Android eMMC phones*
*Some models, like Alcatel and few more, not support that feature!
Security Repair revised in all modes
OTP phones detection enabled during security repair - SW will warn about OTP type if OTP is enabled
"Format FS" option revised for Secured Phones
Unique feature: "Format FS" now rebuild and erase partitions, depend on their types
Unique feature: "Fix Unknow BaseBand" now NOT touch UserData on new (67xx concept) phones!
- Secured phones supported features
"Format FS" operation revised
Flash Read-Write (Dump Mode) Revised
Unique feature: "Fix DL operation" supported
"Security Repair" operations supported
Unique feature: "Reset UserLocks" operation supported
"SmartAV" and "AppManager" operations supported
Repair and test features supported
Unique feature: Forensic operations supported - PhoneBook, PatternLock, UserData
"Smart AV" engine updated
"AppScanner" updated (Dictionary DB also update 1000+ types)
FastBoot mode operations released:
FastBoot layer supported for MTK phones (fastboot.exe is not used)
- Info - Show BootLoader state: locked/not locked, warranty and security state, HW type, SEC_BOOT state
- Unlock BootLoader - Warning! It will erase UserData!
- ReLock BootLoader
- Unlock operations improved
SP Unlock procedure completely revised
Dual Sim phones support improved - Read Correct code / Direct Unlock for BOTH SIM
67xx specifix improvements
Secured Phones support improved
Some other fixes and improvements
New types supported (30+ types)
MT6575/MT6577 FW reader moved on "new Direct mode" - up to 3x faster reading
MT8127/MT8163 [NAND] Factory FW reading improved
- FW Read Extra features:
Unique feature: For NAND now read phone info also, save firmware now like as eMMC - CPU, Vendor, Model, Version, Info
Latest MT6582 (A5/A6 GPT) Factory FW reading should work now
Additional Read features ("Read Additional Files"):
>Create MAUI Meta Modem configarution file (BPLGUI file) eMMC Only
>Create Android-Info.txt file with all Phone Information stored
Stored Info:
PhoneInfo - Model, Version, Brand, Build version etc. for NAND and eMMC
HW Info - LCD, Touch, Modem version etc. (if exists) eMMC Only
BL Info - Compatible IDs of Flash Memory etc. for NAND and eMMC
>Create NVRAM backup during FW read for NAND and eMMC
UserData and Cache reading revised:
Unique feature: SW now build filesystem itself
This give following benefits:
Allow Read FW from "Encrypted" phones without wipe!
No more "Bad ExtData" problems!
Allow ignore any FileSystem problems!
Now FW is completely as factory one!
- Repair ExtData way changed
Now CM2 create and flash all filesystems
Allow recovery damaged phones, which cant be fixed with old method - some Alcatel and others
Alcatel Specific repair options can be found in "Extra->Alcatel"
- DataDirect Engine revised
More faster and accurate
Fixed some types support
Improved PhoneBook Extraction
Improved Gallery Extraction
Secure Platforms supported for PhoneBook and UserData extraction!
- New / Revised models supported
HTC 310, HTC 310w, HTC 320, HTC 526G:
Read/Write Flash - Dump
SP Unlock - Direct
NVRAM and Security operations
Forensic - PhoneBook, PatternLock, UserData
PatternLock and reset UserLocks
Smart AV, AppManager
Init Preloader
Format FS / Reset Settings
Fix DL
Repair Security
Other service and repair features
- Other
Show Full Phone info on ScatterFile selection
DRAM init revised - 50+ new FlashIc supported
DRAM init supported for MT6795 and MT6580
Model list revised, left only Generic, Unlock and Specific models (rest work now in generic or unlock mode)
"Huawei Secured" phones support removed (old and outdated)
Much other different changes, improvements etc.
=== v1.40 ===
New Repair and Test features
MTK SP Platform
- New Features supported:
MTK Android: "HW Test"
Allow Check/Verify phone FlashIc (eMMC), test DRAM memory
Support eMMC:
eMMC Read/Write Test (eMMC ReadOnly verify)
DRAM Memory test: Data Bus, Address Bus, Pattern and Increment tests
Misc HW Test: Battery test (presense, type, level)
[Info]: eMMC test IS COMPLETELY SAFE - it not damage/erase/destroy Android or UserData!
Support NAND:
DRAM Memory test: Data Bus Address Bus, Pattern and Increment tests
Misc HW Test: Battery test (presense, type level)
- Factory Firmware Reading improved
Brand-specific improvements (HTC x64 and Oppo)
Some other improvements and bugfixes
- SmartAV engine improved
Data accuracy level improved
InternalDB updated and revised
APP Scanner improved
- Other
FlashLoaders updated and revised
"Preloader Init" feature improved
FlashID database updated
FlashInit DB updated, new FlashIC types supported
"CRC Errors" should be fixed. Again.
Separate "FRP Reset" option enabled in "Format FS"
Some improvements and bugfixes at all
MTK FP Platform
New types supported
FW reader engine revised
Improved "User Code" read
- Other
Flash Read/Write revised
Some other bugfixes
=== v1.39 ===
New SmartAV and more features
MTK SP Platform
- Flash Engine Revised
Some bugfixes and improvements
Latest FlashUpdate package supported
MTK Android: "App Manager"
Allow remove: Unwanted Apps (garbage, vendor-specific etc.), viruses and rest malware
NO ROOT/USB Debug REQUIRED !!!
Support 2 mode: Dictionary and Manual
Support UserDB: just add all apps, which need to be removed and do it in one click
Forget about waiting updates, request adding new viruses - now you can do all here and now !
[Info]: Check manual about this feature !
Improved "User Gallery" extraction
Improved PatternLock reading ("stuck" problem on some phones fixed)
Engine completely revised, more types supported
- Other
"CRC Errors" problems on some PCs should be fixed now
=== v1.38 ===
DataProtection Unlock and more
MTK SP Platform
Improved booting
Improved HW verification
"Skip HW verification" option enabled
[Info]: Even disabled option still check BaseBand ID to avoid cross-flash!
MTK Android 5.x "Data Protection" unlock read/recover - WorldFirst!
Allow read patternlock, which enable hidden "encrypted" gallery menu
[Info]: DataProtection: It is ecnrypted storage, where can be placed photos,pictures,videos and documents
[Info]: All data inside is encrypted and hidden from normal gallery access!
[Info]: After enter code you will be able to view,decrypt and extract that files
[Info]: "Reset UserLocks" NOT touch that lock! Because of previous reasons.
Revised whole DataDirect engine: PhoneBook, PatternLock, Gallery, SmartAV, UserCodes Reset etc.
64+ GiB UserData storage support enabled!
Support for some "non-standard" FileSystem types
Improved PhoneBook extraction from Android 5.x
Improved Gallery extraction
- SP Unlock revised
Improved new/old/custom security type detection
Improved "Direct Unlock" operation
AGOLD type support under test
Android 5.x specific improvements
Some new NAND types supported (DP, AGOLD)
Engine revised, more types supported
Improved "Security Repair" for some models
- Other
"Oppo" and few other customized preloader drivers supported
"Requested" button enabled
=== v1.37 ===
MT8163 Full Support, MT8127 NAND and more
- Main changes
MediaTek MT8163 ( Quad-core, x64 tablet CPU ) supported for wide range of service,repair and forensic operations!
MT8163 mNAND and eMMC FlashIC types supported
MediaTek MT8127 ( Quad-core tablet CPU ) with NAND FlashIC supported in test mode
New CPU/Platform support
- MT8163 eMMC - World First!
Service: Read Info, Read Extended Info, Format FS, Fix DL , Repair ExtData
UserLock: Read PatternLock, Reset UserLocks - Google, Pin, Password
Other: Factory Reset Protection remove ( Google Reset Protection )
Forensic: PhoneBook extraction , Gallery Extraction
Privacy Lock reset: Normal, Safe mode
Read Factory Firmware (Scatter)
Write Factory Firmware (Scatter)
Read/Write Flash DUMP and NVRAM
- MT8163 mNAND - World First!
Service: Read Info, Format FS
Privacy Lock reset
Read Flash DUMP and NVRAM
SP Platform changes
- Flash Engine updated
MT8163 eMMC Flashing support activated
Supported Platforms for Factory FW Flashing:
MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6795 with eMMC
MT8127/MT8163/MT87xx/MT83xx with eMMC
- Factory FW Read improved
MT8163 eMMC Factory FW reading supported! - WorldFirst!
MT8163 mNAND Factory FW reading supported! - WorldFirst and Unique!
MT8127 mNAND Factory FW reading supported! - WorldFirst and Unique!
MT6571,MT6572 NAND: "Bad SYSData" issue solved for non-standard NAND configs
Supported Platforms for Factory FW Reading:
MT8127/MT8163/MT6571/MT6572 with NAND
MT625A/MT6260/MT6261 with NOR SF
- SmartAV engine updated
Improved verification
Now possible define AV setting by own requirements : Sense level and Limits
- Other
FlashInit DB updated: new flash ICs supported
Boot logs now more informative
Some other changes and bugfixes
=== v1.36 ===
NAND, New Security, AV improvements
MTK SP/FP Platform
Improved MT6582 flashing
"Stuck" issue after flashing with some factory FW files fixed
Improved HW compatibility check
- Smart AV engine updated
- DeepScan improved
- Revised Verification
- Improved Virus removing
- Repair Security improved
MT67xx NewSecurity: Improved repair in case of damaged NVRAM
MT67xx: Improved verification
- Firmware reading improved
SP eMMC: Brand-specific improvements
SP eMMC/NAND: Verification improved
SP NAND: Alternate FW read mode enabled , should cover most existing phones now
FP SF: Improved FW reading, new fw types supported
MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6753/MT6795/MT87xx/MT83xx with eMMC
MT625A/MT6260/MT6261 with SF/NOR
- Other
InitPreloader operation improved
=== v1.35 ===
Nokia 222, New MTK Android and MTK FP features!
MTK SP/FP Platform
Other changes and improvements
- NVRAM operations on SP platform revised
Some bugfixes and changes, some old nvram files will not work anymore
- BB Detection improved
- Compile Info detection improved
- Security Repair Improved
- "FormatFS" revised for MTK Android
New mode supported: Full Factory + FS repair
Option make FullFactory Reset and also repair ExtData
Very useful for "slow" phones, which run after format up to 5-10 minutes and stuck on BootLogo
Android: "Reset UserLocks" operation improved for some models
Android: PhoneBook Reading improved (big DBStorage is supported now)
- Privacy Lock reset improved
MT6580/MT6735/MT6753: PrivacyLock reset supported - WorldFirst!
>Normal Reset
>UserData Safe reset
In both cases by default data will be safe
- Engine completely revised
- DeepScan improved
- Detection revised
- "One virus left" problem fixed
Strongly recomend to use latest version to avoid "hang" problem on some phones!
- Other
FP MTKx Nokia
- New secured FlashUpdate package supported
- New Nokia MTKx models supported:
Nokia 222 SS/DS: RM-1136, RM-1137
Now CM2 support ALL existing Nokia MTK phones
Supported operations: Identify, FormatFS
- New Nokia MTKx Feature - Repair FS during Format - WorldFirst!
Special for Nokia 220 "browser" problem after "FormatFS"
Just use "FormatFS" without any kind of additional settings selection
=== v1.34 ===
MTK SP/FP Platform
Imrpoved MT6582/MT6572 DRAM init
BatteryLevel check during flashing activated
- DeepScan improved
- Detection revised, do not touch sensetive/system data on older platfroms
Strongly reccomend to use latest version to avoid "hang" problem on some old phones!
DataDirect: Improved support for SP and FP platforms
eMMC: Autodetection improved
MT6795-specific improvements
- Other
=== v1.33 ===
NAND Factory FW Read, MTK Anti-Virus, DataDirect LevelUp
MTK SP/FP Platform
- New feature supported : Smart AV - World First and Unique!
Allow: Erase all KNOWN and UNKNOWN YET viruses, which can inject their code in Android system (Monkey Tes,Time Service and much others)
NOT Require: ADB, USB Debug, Root, Power on also not required
Result: ALL VIRUSES, THEIR DAEMONS, ACTIVE SERVICES, SHELL SCRIPTS, RECOVERY SCRIPTS will be REMOVED permanently.
Side Effect: For some type of viruses after remove - mobile will not be affected by those one!
Side Effect: Can REMOVE Root or Root Manager (SuperSu) in some cases!
Required after virus remove make "FULL FACTORY RESET". All USER DATA will be DELETED! Backup it before operation!
Emergency requirement: If FW for target phone not available - MAKE FW READ BEFORE and mark it as "INFECTED_MTxxx_...." !
Supported Platforms:
SP: MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6753/MT6795/MT87xx/MT83xx with eMMC
- New feature supported: NAND Factory Firmware Reading - World First and Unique!
Allow Read Factory-like scatter file for NAND phones with UBIFS FileSystem!
Supported platforms:
SP: MT6571/MT6572 with NAND
- DataDirect: New feature - Recovery Gallery! - World First and Unique!
Allow DIRECTLY Recover User Photos, Pictures
Allow DIRECTLY Recover User Recordings
Allow DIRECTLY Recover User Video records
Tested with recovery files up to 2 GiB per file!
FP: MT625A,MT6260,MT6261
NOTE: Feature NOT intended to recovery "garbage" content, like music etc.
NOTE: Some old android versions can be not supported yet
About DataDirect feature:
Feature allow recover UserData from damaged/hang/semi-dead MTK Phones and SmartPhones WITHOUT need even power on it!
- Internet connection IS NOT required - all data is private and safe.
- USB Debug/Root etc. IS NOT required - forget about root and rest stuff.
- Alive/working phone/Meta mode etc. IS NOT required
Phone can be completely dead (can not be Powered-On)
If phone can Boot and is not erased - data will be recovered
- Its not required to read our tons dumps and waste 20..200 minutes to read dump
Use any sw to extract something from dump, then ... then .. then ... Just ONE CLICK , 10-40 seconds and you got a result!
PhoneBook Reading improved on SP platform - some older Android versions supported
PhoneBook Reading improved on FP platform - more types supported, autodetection improved
FP Firmware verification improved, more types supported
MT6571/MT6572 with NAND supported
MT6580-Specific Improvements
Alcatel-Specific improvements
- Alcatel Pro-Info tool updated
Supported latest Alcatel SmartPhone models (inluding MT6580)
- Other
Much internal changes in different operations
=== v1.32 ===
MTK Android Clear "Reset Protection" and more features
MTK SP Platform
Format FS completely revised
- FMT settings removed for SP eMMC , not need anymore
- New options for reset supported :
FULL FACTORY RESET - Clear ALL settings, including "Google Reset Protection" - World First!
DINNV RESET - used in latest CPU's
Different combinations , for expert use only
In 99% cases enough - Full Factory Reset
- Other
Compile Info extraction improved
NAND operations improved
MTK FP Platform
- Factory FW reading improved
More different FW's types supported
- Forensic Engine updated
More PhoneBook types supported for extraction
- Security repair improved
Security repair on MT625x-MT626x improved
- Other
FlashID Database updated
=== v1.31 ===
MTK FP Factory FW reading, more CPUs/repair/forensic features
MTK SP Platform
- USB Flashing improved
Flash Engine revised
FW Reader revised
MT6735M/MT6735/MT6753/MT6580 specific improvements
- Other
MTK FP Platform
- MTK2502 (Aster) Supported - WorldFirst!
- MTK6261 new version Supported - WorldFirst!
- MTK Feature Phone: Factory FW reading Released - WorldFirst!
Supported platforms: MT625A,MT6260,MT6261,MT2502 NOR_SF
Allow reading Factory FW (1-to-1 as factory) from all MTK FP phones!
Secured phones - Nokia, Alcatel NOT supported!
FW can be flashed via factory uploader
FW flash engine in CM2 will follow
New PhoneBook types supported for extraction
UserCode reading improved for some models
New mode for security repair on MT625x-626x released
- Other
DRAM Init improved for SP phones
=== CM2MTK v1.30 ===
MT6753 support: Flash/Repair/Unlock/FactoryFW/Service/Forensic
Engine updated:
- Dongle Serial Number and Version read method updated
- Activation mode for other Infinity products supported
MTK SP Platform
- New CPU supported: MediaTek MT6753
Service: Security Repair, Read Info, Read Extended Info, Format FS, Fix DL
Unlock: SP Unlock via "Direct Unlock" and "Read Codes"
UserLock: Read PatternLock, Reset UserLocks - Google, Pin, Password etc.
Extra: Flash Erase, Repair Unknown BaseBand, Init Preloader
Read and Write: Factory Firmware
Read and Write: Flash (Dump), NVRAM
MT6753 Flashing support activated
MT6753 eMMC supported
- NVRAM operations revised
MT6753 supported
"BaseBand Version" detection improved
- SP Unlock improved
MT6753 SP Unlock support activated
"Read Codes" and "Direct Unlock" supported
UserLocks Reset improved on SP platform
- Security Repair improved
Security Repair supported for MT6753: CM2 Permanent
Fix Unknown BaseBand revised: MT6753 supported
Some bugfixes
- Other
=== CM2MTK v1.29 ===
MTK67xx New Security SPUnlock! More CPUs, Extra and Repair features
MTK SP Platform
- MediaTek MT6735/MT8735 new revision ID supported
FW Reader revised
SPFT compatibility improved for latest CPUs
"Encrypted" phones FW reading support (in combination with ExtRepair feature)
- MT67xx New Security phones support activated!
Allow make "Read Codes" operation on new security - WorldFirst!
Allow make "Direct unlock" operation on new security - WorldFirst!
New models supported:
Alcatel 4027X (Pixi3 4.5) - Direct Unlock
Alcatel 5017X (Pixi3 4.5) - Direct Unlock
MT67xx changes and improvements
- Repair ExtData feature released - WorldFirst!
- Allow Fix damaged EXT partitions!
Fix "Bad EXTData" error during Factory FW reading
Fix "Hang/Stuck" on Boot logo*
*only in case of damaged user partitions, when "Format FS" not help
Fix/Format/Repair "FS Encrypted" Phones
MT6571/MT6572/MT6575/MT6577/MT6580/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6795/MT87xx/MT83xx with eMMC
- Format FS revised
"Backup" operation for SP phones removed. Not need anymore.
- MT6571/MT6572 NAND support revised
No need make "Identify" before opeartion for most phones
Format FS revised
PatternLock reading improved
- Other
FlashInit revised for all supported platforms
=== CM2MTK v1.28 ===
MT6580 support: Flash/Repair/Unlock/FactoryFW/Service/Forensic
MTK SP Platform
- New CPU support
- MT6580 - World First!
Read/Write: Flash, NVRAM
MT6580 Flashing support activated
MT6580 eMMC supported
MT6580 supported
- MT6580 SP Unlock support activated
- Fix Unknown BaseBand revised, MT6580 supported
- Some bugfixes
- Other
=== CM2MTK v1.27 ===
MT6595 Real support: Flash/Repair/Unlock/FactoryFW/Service/Forensic
MTK SP Platform
- New CPU support
- MT6595
FlashUpdate Package updated to v7.1533.03
MT6595 Flashing support activated
MT6571/MT6572/MT6575/MT6577/MT6582/MT6589/MT6592/MT6595/MT6732/MT6735/MT6752/MT6795/MT87xx/MT83xx with eMMC
MT65xx New "type" structure supported
MT6595 eMMC supported
MT6595 supported
- MT6595 SP Unlock support activated!
- Support MT65xx models with "new type" structure for "CM2: Permanent mode"
- Fix Unknown BaseBand revised, MT6595 supported
- Some bugfixes
- Privacy Protection password (UserData Safe mode) improved for some Android versions
- Some improvements in forensic engine
- Other
32+ GiB FileSystems support improved for Forensic/Service operations
FlashId database updated (FP and SP platforms)
NAND structure detection improved
Revised "Secured" platforms support (Huawei,HTC)
=== CM2MTK v1.26 ===
Nokia MT6261, MT6735/MT8735, New MTK Android features, more CPUs
MTK SP Platform
- New CPU support
- MT6735/MT8735
UserLock: Read PatternLock, Reset UserLocks (Google, Pin, Password etc.)
Unlock: SP Unlock via "Direct Unlock" and "Read Codes" (Under Test)
MT6735/MT8735 Flashing support activated
MT6571/MT6572/MT6575/MT6577/MT6582/MT6589/MT6592/MT6732/MT6735/MT6752/MT6795/MT87xx/MT83xx with eMMC
Brand-specific improvements (Meizu, Xiamoi, Qmobile, Lenovo, Alcatel)
MT67xx New "type" structure supported
MT6735 eMMC supported
MT8735 eMMC supported
- New Feature - Read Extended info
Allow read: All hardware info (LCD/Touch/Camera/rest info) and software info (Including languages)
Support most "unknown" brands/models and 3rd party models (some original brands supported as well)
Useful for seeking spareparts, identify HW, compare firmwares, cross-flashing "noname" phones
Supported Platforms: MT6571/MT6572/MT6575/MT6577/MT6582/MT6589/MT6592/MT6732/MT6735/MT6752/MT6795/MT87xx/MT83xx with eMMC
MT6735/MT8735 supported
Now default name is "BaseBand Version" (if possible to identify it)
Allow identify NV files for "unknown" brands
Allow use same BB version NVRAM for different phones
- MT6735/MT8735 SP Unlock support activated (Under Test)
- New models included:
MTS Smart Run 4G
- Direct Unlock revised
- Support MT67xx models with "new type" structure for "CM2: Permanent mode"
- Fix Unknown BaseBand revised for latest platforms
- Some bugfixes
- Forensic Engine revised
Improved PhoneBook extraction for old Android versions (4.0.x - 4.x.x)
Improved PhoneBook extraction for Android 5.x versions
Revised output formats - VCFv2 supported (combined), VCFv3 supported (combined)
Total supported formats: CSV (Google), VCFv2 and VCFv3 (combined single), TXT (readable/printing)
- NAND PatternLock reading revised
- Other
MT6580 eMMC support under test (Service/Unlock/UserLocks/Forensic/FWReading/Info)
MT6753 eMMC support under test (Service/Unlock/UserLocks/Forensic/FWReading/Info)
Generic NAND support revised
MTK FP Platform
- FlashLoaders updated
- Nokia 105 series phones support activated!
*Read Info / Check
*Format FS
Supported models: RM-1134, RM-1135, RM-1136
Now CM2MTK module support ALL exisitng Nokia MTK phone for basic operations!
- UserCode reset revised for some models
- Some improvements in Forensic Engine for MT6260/MT6261 phones
Other (Main)
- Connection revised for FP/SP
- Some bugfixes and improvements
=== CM2MTK v1.25 ===
CM2MTK v1.25 - MT62xx/MT65xx/MT67xx/MT8xxx Forensic - Direct PhoneBook extraction
FP Platform:
- MediaTek MT625A,MT6260,MT6261 : Direct PhoneBook Read - WorldFirst
Hang/Dead/SemiDead/Broken phones also supported
Until phone can boot and not erased - data can be recovered
Output formats : CSV (Google), TXT (readable/printing)
SP Platform:
Improved flashing for MT6582 platform (Lenovo and some other brands/models)
Some fixes and improvements
- Service operation improved
Preloader init improved: Show all HW info, compatibility check improved
Support latest brand-specific changes for some models
Autodetection for unknown types improved
MT6571, MT6572, MT6575, MT6577, MT6582, MT6589, MT6592, MT6732, MT6752, MT6795, MT8xxx eMMC : Direct PhoneBook Read - WorldFirst
- Other
Some bugfixes
Currently support features:
- PhoneBook Reading
Supported devices:
- Chinese brands - MTK Android OS, MTK Feature phones
- Original brands - Alcatel, ZTE, HTC, Meizu, Xiamoi etc. - MTK Android OS, MTK Feature phones
=== CM2MTK v1.24 ===
Chinese Miracle-2 MTK/MediaTek v1.24 - Security Repair, Reset Google Account and more
MediaTek SP Platform
- Support latest brand-specific changes for Micromax, Karbonn, ZTE phones
- Improved verification and post-checking
- Reset "Google Account" without any byte of UserData lost. The next platforms supported:
MT6571, MT6572, MT6575, MT6577, MT6582, MT6589, MT6592, MT6732, MT6752, MT6795, MT8127 eMMC only.
Method NOT patch any system data. Method DO NOT destroy user security by residents reset scripts etc.
Method work like deactivate lock via phone settings. No need to enter anything.
No need USB Debug, Root and rest things.
All Android 4.x and 5.x versions supported (old 4.0.x may have problems)
- Repair Security revised. Support new mode: CM2 Permanent
Supported Platforms: MT6571/MT6572/MT6575/MT6577/MT6582/MT6589/MT6592/MT6732/MT6752/MT6795 with eMMC
Dont use usb debug/root etc.
Support all non-secured MTK phones !
NOT support Alcatel phones with OTP !
Other
- Revised CompileInfo extraction
- "Fix Unknown BaseBand" revised
- Alcatel "ProInfo tool" revised
- Some bugfixes
=== CM2MTK v1.23 ===
Chinese Miracle-2 MTK/MediaTek v1.23 - MTK Android reset all UserLocks without data loss
- MediaTek MT6752/MT6795 brand-specific improvements
Service Operations improved
- "Fix Unknown BaseBand" revised for some platforms
- "DLFix" (DL Image Tool Fail error repair) support fixed for MT6592
UserData Operations improved
- Reset Phone PIN code ( Without any byte of UserData lost! ) supported for the next platforms:
- Reset Phone Password code ( Without any byte of UserData lost! ) supported for the next platforms:
- Reset Phone "FaceLock" and "VoiceLock" ( Without any byte of UserData lost! ) supported for the next platforms:
Method DO NOT patch any system data.
Method DO NOT destroy user security by reset scripts etc.
Method work like deactivate lock via phone menu, no need to enter any key combinations or something like that.
No need USB Debug/Root etc.
PatternLock can be reset also but its strongly recommend to use "Read PatternLock" instead of reset.
Other
- MT8127 support was broken since v1.22 due loader update. Fixed.
- Some Bugfixes and improvements at all
=== CM2MTK v1.22 ===
Chinese Miracle-2 MTK/MediaTek v1.22 - MT6795, Android 5.x and more
- MediaTek MT6795 [HelioX10] Flashing supported
Factory FW and Dump flashing
- Factory FW writing revised for some platforms
- MT67x2 improvements
Supported CPU for Flash Writing:
MT6575, MT6577 eMMC only
MT6571, MT6572, MT6582, MT6589, MT6592, MT83xx eMMC only
MT6732, MT6752, MT6795, MT8752 eMMC only
MT8127 eMMC only
- MediaTek MT6795 [HelioX10] Factory FW reading supported
- Big firmware handling improved: MT659x, MT67xx
- Factory Firmware size now more compact - up to 2 times for some models
- "Fix Unknown BaseBand" supported for MT6795
- "DLFix" (DL Image Tool Fail error repair) supported for MT6795
- "Flash Erase" supported for MT6795
- NVRAM operations supported for MT6795
- "Format FS" (UDA + CACHE) supported for MT6795
- "Write Flash" / "Read Flash" (DUMP) supported for MT6795
- "Fix DL" during PrivacyLock reset and "Format FS" now made automatically
Unlock Operations improved
- "Direct Unlock" operation supported for MT6795
- "Read Unlock Codes" operation supported for MT6795
- New models supported
Beeline Pro 2
Beeline Smart 3
Beeline Smart 4
Beeline Tab Pro
MTS 982T
MTS Smart Start
- Privacy (AntiTheft) Lock reset supported for MT6795
- Privacy (AntiTheft) Lock reset without UserData loose supported for MT6795
- UserData Safe Privacy (AntiTheft) Lock reset revised for big storage devices (16+ GiB)
- PatternLock Read supported for MT6795
Other
- Latest FlashUpdate package supported (v1520)
- Android 5.x OS support improved
- Repair Security improved for some models
=== CM2MTK v1.21 ===
MT6592 Flashing supported!
MT6575/MT6577 Flashing improved
Big ROM flashing improved
MT6732, MT6752, MT6753, MT8752 eMMC only
MT8127 eMMC only
MT6592 Factory FW reading improved
Some HTC phones support improved (HTC 320, HTC 626, HTC 526)
- Service Operations improved
"InitPreloader" supported for MT6592
"Fix Unknown BaseBand" supported for MT6592
"DLFix" (DL Image Tool Fail error repair) supported for MT6592
"Flash Erase" supported for MT6592
NVRAM operations supported for MT6592
"Format FS" (UDA + CACHE) supported for MT6592
"Write Flash" (DUMP) supported for MT6592
Alcatel "ProInfo Tool" activated for MT6592
- Unlock Operations improved
"Direct Unlock" operation supported for MT6592
HTC 526G (MT6592)
HTC 626G (MT6752)
HTC 320 (MT6582)
- UserData Operations improved
Privacy (AntiTheft) Lock reset supported for MT6592
Privacy (AntiTheft) Lock reset without UserData loose supported for MT6592
- Other
Android 5.x OS support for: PatternLock Read, Safe PrivacyLock reset, Full Identify
Most fixes for 5.x is for speed-up operations
No USB Debug, Root required
DRAM Init improved: MT6592, MT6572, MT6732 supported
CompileInfo extraction for DUMP Read/Write was broken, fixed
=== CM2MTK v1.20 ===
Android PrivacyLock reset without UserData loose and more!
Latest FlashUpdate package supported (v1516/2015)
DRAM init improved
MT6575 Factory FW reading improved
InitPreloader improved for MT6575/6577
DRAM init revised for some platforms
Privacy (AntiTheft) Lock reset without any byte of UserData loose - World First!
MT6571, MT6572, MT6582, MT6589, eMMC only
MT6732, MT6752, MT6753, MT8752, eMMC only
MT8127, eMMC only
No Root, ADB, USB Debug required
- Other
Improved support for different OS - CRC errors should gone etc.
=== CM2MTK v1.19 ===
MediaTek 64Bit is ON! SPUnlock/FactoryFW/Service and more!
MediaTek MT6732 Flashing supported - World First!
Mediatek MT6752/MT6753/MT8752 Flashing supported - World First!
Mediatek MT6582, MT8127, MT6571 Flashing revised
CPU supported now for Factory FW flashing:
MT6571, MT6572, MT6575, MT6577, MT6582, MT6589, eMMC only
MT8127, eMMC only
MT6732 Factory FW reading supported. Result is Factory-like one! - World First!
MT6572/MT6753/MT8752 Factory FW reading supported. Result is Factory-like one! - World First!
No ADB, USB Debug, Root required
Some other improvements for brand specific models for all supported platforms
CPU supported now for Factory FW reading :
MT6571, MT6572, MT6575, MT6577, MT6582, MT6589, MT6592, eMMC only
MT8127, eMMC only
NVRAM operations revised for all supported platforms
Format FS revised for all supported platforms
- World First MT6732/MT6572/MT6753/MT8752 features:
Full Flash ( DUMP ) Read/Write supported
Safe Format FS supported ( UDA/Cache )
Repair Security supported
Identify/Read info supported ( "All info" feature also supported )
Reset Privacy Lock support ( Under test )
Fix DL supported
Read/Write NVRAM operations supported
Flash Erase supported
Fix Unknown BaseBand supported
MT6732: Generic "Read Codes" / "Direct Unlock" supported! - World First!
MT6572/MT6753/MT8752 : Generic "Read Codes" / "Direct Unlock" supported! - World First!
New Models supported for "Direct Unlock" / "Code Read":
ZTE Blade A430 ( MT6732 )
ZTE Fit 4G ( MT6732 )
ZTE Blade Q Lux ( MT6732 )
ZTE Beeline Pro ( MT6732 )
MT6572 NAND PatternLock reading improved
PatternLock Reading activated for MT6573 and MT6575 NAND phones!
PatternLock Reading activated for MT6732/MT6572/MT6753/MT8752 - World First!
- Other
Drivers updated
=== CM2MTK v1.18 ===
MT6575/MT6577/MT6589 Factory FW and more
- MTK Flash Engine:
- Flash Engine rewritten
- MT6575/6577 Factory Firmware Flashing enabled
- MT6583/6589 Factory Firmware flashing enabled
- MT6582 Factory Firmware flashing improved
- MT6575/6577 Erased phones support activated
And other important bugfixes for all supported platforms
CPU supported now for Factory FW flashing: MT6571, MT6572, MT6575, MT6577, MT6582, MT6589, MT8127, eMMC only
- MT6575 supported (eMMC)
- MT6577 supported (eMMC)
Allow read complete firmware with all mandatory parts as factory one!
Some improvements for specific models support on different CPUs
CPU supported now for Factory FW Reading: MT6571, MT6572, MT6575, MT6577, MT6582, MT6589, MT8127, MT6592, MT83xx eMMC only
- SP Unlock operations improved
- Read Codes now read both SIM codes for DualSim phones
- Direct Unlock improved
- "Fix Unknown BB" improved (some NAND problems fixed)
- Pattern Lock reading improved (some NAND fixes)
- Flash Init completely revised
.MT6575/MT6577 supported
.MT6589 support improved
- "Init Preloader" improved, MT6575/MT6577 support activated
- Flash Init completely rewritten for "Init Preloader", Factory FW flashing, Flash (Dump) writing
- Identify now possible with "Read All Info" for MT6575/MT6577 eMMC phones
- Alcatel "ProInfo" operations improved
MediaTek FP Platform
- MTK 652A/MT6260/MT6261 Read User Code improved
MediaTek All
- Other
FullFlash Read/Write revised for MT6575/MT6577
Improved CompileInfo extraction
=== v1.17 ===
Alcatel, HTC and new extra features!
- MTK Flash Engine:
1. Flashing with "Flash Erase" and "Repartition" work now like "Download Only" mode
2. Some other improvements
CPU supported now for Factory FW flashing: MT6571, MT6572, MT6582, MT8127, eMMC only
HTC 310 (Read Codes)
HTC 616 (Read Codes)
HTC 620G (Read Codes)
Alcatel 5038 (Direct Unlock)
Alcatel P310 (Direct Unlock)
MT6589 "SP Code Read" and "Direct unlock" revised
MT6571/MT6572 NAND supported for "Read Codes"
ADB/Root is not required
HTC and Alcatel specific improvements
- Service operations improved:
HTC 310 support (SP Unlock / Read/Write Dump / Format FS / Read PatternLock) - HTC 310 model should be selected !
New Feature: Alcatel ProInfo Tool: Read ProInfo, Write ProInfo, Edit ProInfo
* Support for ProInfo write: Binary and Infinity format files
New Feature: Flash Erase - for expert use only !
* Support MT6571, MT6572, MT6582, MT6589, MT8127, only eMMC supported
New Feature: Fix Unknown BaseBand - for expert use only !
* Support MT6571, MT6572, MT6582, MT6589, NAND/eMMC supported
New Feature: Init Preloader - for expert use only !
* Support MT6571, MT6572, MT6582, MT8127, MT6589, only eMMC supported
- MTK 652A/MT6260/MT6261 Read User Code activated (Reset option still exist)
Read one and correct user code and it state (active or not)
- MTK 652A/MT6260/MT6261 Read "Privacy Lock" and "Mobile Tracker" codes activated
Read one and correct PL or MobileTrack code (or both if set)
MediaTek All
- Other
FlashUpdate Package updated to latest (v1512/2015)
FullFlash Read/Write revised for MT6572/MT6589
MT6589 Support revised, FlashInit activated
Secure Boot phones (MT6582, MT6589) support revised
=== v1.16 ===
MT8127 support and more features
- MT8127 Full Support ( World First! )
1. Identify / Read full Info
2. Read Dump / Write Dump
3. Read Factory Firmware w/o Root/Debug/ADB
4. Flash Factory Firmware
5. Format FS (UDA/CACHE)
6. Read Pattern Lock w/o Root/Debug/ADB
7. Reset Privacy Lock
8. Fix DL
- Factory FW Reading improved
1. MT8127 supported
2. MT6592 support improved
CPU supported now for Factory FW reading: MT6571, MT6572, MT6582, MT6589, MT6592, MT8127
NO Root/ADB/Debug required for read Firmware
- MTK Flash Engine rewritten:
1. MT8127 Support, MT6572 and MT6582 support improved
2. Flash Pre-erase revised
3. Force Repartition option enabled
4. Flashing speed improved
5. AfterFlash Verify revised
6. PL SW/HW check improved
7. Support MT6571 ScatterV2
HTC 210 - Read Codes/Direct Unlock
Megafon Login 3 - Read Codes/Direct Unlock
Megafon Optima - Read Codes/Direct Unlock
Huawei G610 - Read Codes
Alcatel 4018/4032/4035/6012 - Read Codes
- MTK65xx Generic SP Code Reading activated (71|72|82|89|92 eMMC)
Allow Read SP codes (All 7 levels) from MTK SP Phones. Wide range of different models supported.
- MTK65xx Generic SP Direct Unlock activated (71|72|82|89|92 eMMC)
Allow Direct Unlock MTK SP Phones. Wide range of different models supported.
Unlock via Code Read or Direct Unlock DO NOT require Root/Debug/ADB
- Other
FlashUpdate Package updated (v1504/2015)
"FIX DL" activated for MT6582
Flash Init activated for MT8127 (Erased Preloader support)
1. NAND support improved - now supported most MT6571/MT6572 NAND
2. MT8127 PatternLock Reading activated
"Read Full Info" option activated for Flash (Dump) reading
Fixed Info extraction delay after Dump reading
Fixed CompileInfo extraction
"Secure Boot" option removed from Model List. For Secured Huawei MTK use correct Model Selection!
=== v1.15 ===
New feature supported: SP Unlock
Supported models:
Megafon-Login+ [MT6582]: Direct Unlock
Megafon-Login2 [MT6572]: Read Unlock Codes
Huawei-Y330-U01 [MT6572]: Read Unlock Codes
No ADB/Root required, more models will follow.
Factory FW read improved (auto detect unknown types in most cases now)
Factory FW (Scatter-Defined) Flashing improved
PatternLock read improved (wrong pattern in some cases was shown)
Repair Security Improved
Other
=== v1.14 ===
MTK Nokia 215 Support
- Activated Nokia 215 support
Supported Revision: RM-1110, RM-1111, RM-1112
Supported Operations: Read Info, Format FS
Other:
FlashUpdate packaged updated
Note:
Nokia MTK phones require Nokia Serial driver (download it from Support Area)
=== v1.13 ===
MTK Android Scatter Flashing
- Activated Scatter-Defined Flashing Support
Supported Models: eMMC-based MT6571, MT6572, MT6582
Supported conditions: Empty Board/Erased Flash etc.
Supported modes: Flash, Flash + Erase (Safe), Flash + Erase (Safe) + Verify, Flash + Verify
Support full check: HW initial check, eMMC compatibility check (not allow kill phone by wrong fw)
Alcatel Original Scatter Flashing supported
Other:
Flash Init activated for MT6582 (erased phones supported)
Notes:
Supported only Factory Scatter Files and Scatter files made by CM2 module
Other box/tools files is not supported (due garbage/wrong files and data) but anyway can be flashed
=== v1.12 ===
- NAND: Pattern Lock reading activated for MT6571, MT6572
No need Root, No need USB Debug, No need modify system files, No warranty lost
- Privacy Lock reset improved: NAND fixes, MT6582 support activated
- Factory Firmware Reading Improved
- NVRAM operations improved:
Support ifnv and any binary backup (plain)
Secure phones support improved
- FlashUpdate package updated to latest
Other:
- NAND/eMMC init improved
- Format FS revised
- FlashID database updated
=== v1.11 ===
New feature supported: NVRAM Read/Write
- Read NVRAM data: MT6571-MT8392 (NAND/eMMC)
- Write NVRAM data: MT6571-MT6589, MT8312-MT8389 (eMMC only)
"Privacy Lock" Reset improved
- MT6571 NAND supported
- MT6572 NAND supported (under test)
- Structure detect now 5-6 times faster for "slow" phones (Mostly MT6571)
- Read operations improved for MT6573/MT6577
Factory Firmware reading engine updated
- Support more different types (mostly - brand-specific)
- Some bug fixes ad improvements
Secure Mode support improved
- Some bugfixes on flash pre-erase for MT6261
Other:
Some BugFixes and improvements at all
=== v1.10 ===
More Models and Features
MediaTek SP Platform:
MTK6572/MTK6582 Secure Phones support
- Identify/Read Info
- Read/Write Flash
- Format FS
- Read PatternLock (No USB Debug, No Root, No Modify System and harm User-Level security)
Mostly Secure phones - Huawei Android phones (Huawei Y330, Huawei G610 etc) and other brands
Read Factory Firmware (Scatter - format) improved
- Universal way for most Chinese Brands/Models is work now
- MT83xx (Tablet specific) improvements
- Improved Alcatel, HTC, ZTE, Huawei and other brands support (Model/Brand specific-types)
Other:
Some bugfixes from previous update (SP Flash, SP FW Read)
=== v1.09 ===
New feature supported: Read Factory Firmware (Scatter - format)
ADB Debug Enable IS NOT required
Root IS NOT required !
Supported phones (CPU):
MT6571 eMMC
MT6572 eMMC
MT6582 eMMC
MT6583 eMMC
MT6589 eMMC
MT6592 eMMC
MT83xx eMMC (Tablet)
Supported Android Versions: All (up to latest 4.4.x)
Support Different Chinese brands
Support ORIGINAL: Alcatel, HTC, ZTE, Huawei
Other:
Privacy Lock reset improved (eMMC)
Format FS procedure improved
=== v1.08 ===
MTK SP (Android) eMMC:
- Reset Privacy Lock (AntiTheft Lock) released - World First
Allow reset "Privacy Protection Password" without FullFlash Erase, Destroying phone calibrations etc.
Mostly used for MT6571/MT6572 phones
- Fix DL option released - World First
Allow fix "DL Tool Fail" and rest start-up errors after "Flash Write", "Format FS", "Reset PL"
No need factory firmwares etc.
That option allow now support original HTC, Acer, and some other brands with MTK65xx CPU
- Format FS improved
- FlashId database updated
MTK SP (Android) NAND:
- Improved "Read Info" operation
- Improved "Read Flash" and "Format FS" operations
Other changes:
FlashInit improved
Repair Security for MTK SP phones improved
Other fixes and changes
=== v1.07 ===
.Universal NAND support for MT6571/MT6572/MT6575/MT6577 released *
.MT6573 support released (Read Info/Read Flash/Format FS)
.MT6575/MT6577 NAND support fixed
.MT6575/MT6577 eMMC support improved
.Repair Security improved
Other:
.Flash Pre-Erase revised
.Format FS procedure revised for eMMC phones ( simplified and removed extended settings ) **
.Added support for "Format FS" on non-aligned PMT phones ( Some MT6575 eMMC phones, like - Alcatel, Lenovo and some MT6573 NAND )
.FlashInit improved
.Compile Info extraction improved
.MT6575/MT6577/MT6573 NAND Compile Info extraction enabled
.FlashID database updated
.Reset user code operation improved
.FlashId database updated
Other:
Notes :
* It is mandatory now make "Read Info" before other operations for NAND phones
** If need full rest ( "Wipe"/"Clean" ) - Set to "0" always. If need preserve some vendor apps - use software defined or own set.
If phone "hang" on logo - do format again with "0" settings.
=== v1.06 ===
MT65xx Repair security support and more
.Cross CPU/Flash file checking ( not allow cross-flash different firmware )
.Repair Security options activated
Tested and supported CPU:
MT6571,MT6572,MT6575,MT6577
MT6582,MT6583,MT6589,MT6592
MT8312 series
Support up to 4 IMEI repair
Other:
.Format FS procedure revised: backup/checking
.FlashInit improved
.DebugLog reading enabled - for test/repair purposes
.Repair Security operation improved
.Support for 4th IMEI is activated
Other:
Drivers updated
=== v1.05 ===
Nokia 108/130/220/225 support
Other:
FlashInit improved
New CPU/Models supported:
Nokia MT625A: Nokia 108 (RM-944, RM-945), Nokia 220 (RM-969, RM-970, RM-971)
Nokia MT6260: Nokia 130 (RM-1035, RM-1036, RM-1037), Nokia 225 (RM-1011, RM-1012, RM-1043)
Supported Features:
Check/Read Info
Format FS (Safe Format/Reset Settings)
Other:
Required to use special drivers for Nokia MTKx phones (uploaded on support)
Flash Read/Write is useless due security protection
=== v1.04 ===
.PatternLock Reading improved
.MT6582 support improved
.MT6571 eMMC support improved
.FlashInit improved
.Flash Read/Write speed improved
=== v1.03 ===
Activated eMMC support on following CPU:
MT6592
Operations:
Read Info/Check
Read Flash
Read PatternLock
New feature supported: PatternLock Read
Root IS NOT required, No system modifications, No Warranty void
MT6571 eMMC
MT6572 eMMC
MT6575 eMMC
MT6577 eMMC
MT6582 eMMC
MT6583 eMMC
MT6589 eMMC
MT6592 eMMC
MT8312 eMMC
Supported Android Versions: All 4.x.x (up to latest)
Other:
MT6583 support improved
MT6572 NAND support improved
MT6571 NAND support improved
MT6575 eMMC support broken in latest FlashLoaders, fixed
Initial boot revised (MT659x support)
FlashInit improved
MT6260, MT6261, MT625A: improved latest FlashLoaders support
=== v1.02 === MT6571 NAND/eMMC support , Generic 6571/6572 NAND support
MediaTek SP Platform :
Activated NAND support on following CPU's :
MT6571
MT6572
Supported features :
Flash Read
Format FS ( Cache, UDA , UDA+CACHE )
Read Info/Check
Activated eMMC support on following CPU's :
MT6571
Other :
FlashInit : support some models with not active Preloader, or erased Flash
HSUSB : Init fast flashing / flash reading , if phone have not active Preloader, or Flash erased
FullFlash Dump Integrity check (During Read/Write)
SP FlashLoaders updated
MediaTek FP Platform :
MT6260,MT6261,MT625A : Format FS procedure revised
MT6260,MT6261 : Empty (Blank) FlashIC support
=== v1.01 ===
.MediaTek MT6261 CPU supported
Read Info / Check
Write Flash
Read Flash
Format FS
Repair Security
.MT625A,MT6260 support improved
Support latest FlashLoaders
Improved Format FS procedure
.Other
Some bugfixes
=== v1.00 === MTK Android Support (6572/6575/6577/6582/6583/6589/8312)
- New features and models support released :
.Support new CPU: MediaTek MT6572, MT6575, MT6577, MT6582, MT6583, MT6589, MT8312
.Support FlashSize/Types: eMMC only (up to 32 GB tested)
Operations:
.Read Info/Check
.Read Flash (FullFlash)
.Write Flash (FullFlash)
.Format FileSystem (Reset Settings): UDA (UserData), Cache
Other:
.Full firmware info extraction: version, model, branding and etc.
.Safe Format, backup/restore
- Improved
.MTK 625A: Format FS, Flash Write improved
.Safe Reset User Code (without data lost) improved for MT6260 and MT625A
.Flash File verify during Read/Write operation added
.Initial Boot improved
.Fixed some other minor errors
v0.03
.MTK625A support improved
.Boot procedure fully revised
.CodeDefine base updated
.Improved "User Code Reset" operation
.Repair security improved
.Some bugfixes
v0.02
.Improved USB detection - support for different USB driver versions
.Improved Initial Boot
.Improved File Verification (Read / Flash)
.Backup improved (Format FFS / Reset User Code)
.USB drivers included
.Some bugfixes
v0.01: Initial Test version
.Support interface: USB only (Test Version limitation)
.Support CPU: MediaTek 625A , MediaTek 6260
.Support FlashSize/Types: All 3/4/8/16 MiB
Operations:
.Read Info/Check
.Read Flash
.Write Flash
.Reset UserCode (NO USER DATA LOST)
.Repair Security
