Old 01-23-2010, 06:54   #1 (permalink)
deepaksawdia's Avatar
Member: 108186
Thanks Meter: 241
write imei failed inside firmwere
please see the log
==== log: [1/23/2010 11:04:02 AM] ====
COM3 [VCP0] selected
module v3.07
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 357263025428577
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:A62C:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:2BEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: QING_S07_PCB01_GPRS_MT6223P_S00.QING-S07_MICROMAX_L1EN_206_090107_CAM010_MCP128+32_BT_F M.BIN
project-id: QING-S07_MICROMAX_L1EN_206_090107_CAM010_MCP128+32_BT_F M, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
detect standard ffs/eeprom location pass #1...
detect extended ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
error: error# 000000FF
error: flash write error: 00640000:00002000
error: no any expected answer
error: can't write required area
Old 01-23-2010, 12:17   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what cable/box is used as interface with this phone?
Old 01-23-2010, 13:05   #3 (permalink)
Member: 108186
Thanks Meter: 241
i have infinity pin finder but fast pin finding i always use spiderman box for pin finding
Old 01-23-2010, 16:17   #4 (permalink)
Member: 148515
hello!
yes, this is known Spiderman problem.
you either must use pinfinder or re-install spiderman drivers by awailable on our support site.
Old 01-24-2010, 07:59   #5 (permalink)
Member: 108186
Thanks Meter: 241
please guide me which box we use for quick pin finding
Old 01-24-2010, 13:54   #6 (permalink)
Member: 108186
Thanks Meter: 241
i am not found spiderman driver at infinity support site
Old 01-25-2010, 20:37   #7 (permalink)
Member: 148515
hello!
they use Prolific usb to comport converter.
search for driver in Utility folder
Old 01-26-2010, 06:43   #8 (permalink)
Member: 108186
Thanks Meter: 241
my pin finder give me trouble some time give me message pin finder not found
but i remove the usb cable from infinity box and put again than find but when search command again show pinfinder not found
Old 01-26-2010, 13:24   #9 (permalink)
Member: 108186
Thanks Meter: 241
thanks infinity help ..i have very difficult to use infinity pin finder but after that my problem solve
Old 01-29-2010, 18:34   #10 (permalink)
Member: 108186
Thanks Meter: 241
i download driver from infinity support site
and try to giving new driver many many times to spiderman through device manager but not successsed
. please give me correct method to give new driver
Old 01-29-2010, 20:21   #11 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
we do not provide any kind of support for spider box.
if you have a problem with spider box installation, pls, ask help from Spider supporters.
If you have a problem with PinFinder, pls explain the problem in details due to I can not understand well what is the problem now.
8310 cannot write imei..... kickthepenguin BlackBerry (RIM) 20 03-21-2011 13:34
Failed to write imei..????? sky_finder MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-30-2010 15:45
6230 write imei failed beega Nokia Digital Core Technology 4 ( DCT-4 ) 3 08-26-2006 12:12
D500 solution for write imei failed imo TST Dongle 0 12-16-2005 15:18
2100 write imei failed hyper_wamir Nokia Hardware & Hardware Repair 5 11-18-2003 03:19
Page generated in 0.22387 seconds with 9 queries
