Old 03-16-2011, 22:49   #1 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Wx290 - After flashing, no signal, then dead
Unlocked 312 pieces, but 8 stopped during unlocking, so unlocked them again, and all ok, except 1. so, flashed phone with
M290A-APSAR1-666_XP66GC15_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V40_F5_2010-04-23_En_Nl_Fr_Es_Pt.B0M.bin
Flashed ok, no errors, but phone didnt get carriers signal. So I read firmware from other wx290, already unlocked, and flashed to this one, issue persisted. So, I read full flash from working phone, and flashed to this one, no errors, but phone does not turn on anymore. Tried to unlock again, and got this:
COM9 [VCP0] selected
module  v3.75
Device: Motorola-WX290
Checking data, wait...
Action: rebuild security area
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:8685:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Arquivos de programas\InfinityBox\MModule\backup_security\id.13BEB773.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V40_F5.BIN_C88F339E].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 13BEB773
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V40_F5.BIN
project-id: MAUI.08A.W08.36.SP1.V40.F5, 9E338FC8
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 666
provider: M290X-DAAVBR1
customization: CP66GK19
customization: XP66GK19
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization: *a)v`>r11+,r10+-M1
IP254(ɷJ*kZb72HKԉ=	}) @l	fn44^[vP= P"œh!WAVSᰲt8D7v9弄}XNKg0ˏ>5KB	1u	{M>ӧZ25lEhG"vY+:6OKJмs/ITK*go#vM<)Oswarning: customization name is unknown
Can not calculate required data !
Find original simfree model, read full flash and send to support
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
original imei: 35203204067684
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Motorola-WX290_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V40_F5__system_log_13BEB773_C88F339E_20110316-183458.B0X.bin
Finished, time used: 3 min 23 sec
Remove/Install battery now !
so, original full flash backup from working phone (simfree by infinity)
http://www.celiovaz.com/request/Moto...182111.B0M.bin
[link again]
br
Old 03-17-2011, 23:39   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
We will check original flash backup asap and let you know about results.
Old 03-18-2011, 00:02   #3 (permalink)
Member: 130995
Hello,
As I can see phone original firmware version was:
It was simfree 290X phone (for Europe), so it can not take signal in America due to band difference.
Please, check, what is exact model name (from phone back label).
Old 03-18-2011, 16:07   #4 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Hello,
Phone is 290x. Please dont misunderstand AMERICA with USA. USA is a country that uses 850/1900, while America is a big continent, with 3 portions (North, Central and South). Brazil, as others, uses 900/1800 band, so phone have to get carriers signal, as the others 319 did.
br
Old 03-18-2011, 18:27   #5 (permalink)
Member: 130995
Hello,
Yes, I know what is USA and what is America, but anyway, thanks for explanation
I thought that almost all operators in whole America (North, Central, South) use 850/1900.
If in your country you have 800/1900 bandd you have to flash phone with another 290X firmware (X is for 800/1900, A for 850/1800) and see results.
Probably you have to try to use several firmware files to get results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-18-2011, 20:52   #6 (permalink)
daroas's Avatar
Member: 194078
hi sir,is possible convert WX290 850/1900 for 900/1800?
Old 03-19-2011, 02:05   #7 (permalink)
Member: 130995
If you have flashed "A" phone with "X" firmware and if you see no signal - this means that it is need to modify phone hardware, not only change firmware.
You can try and see results, I will be glad to see what was your results.
Old 07-02-2011, 13:07   #8 (permalink)
Cryspim's Avatar
Member: 62561
Here in Brazil (in my city), we have 4 operators, as follows:
Claro: 900/1800 Mhz
Oi: 900/1800 Mhz
TIM: 900/1800 Mhz
Vivo: 850/1900 Mhz
Its quite common Vivo Operator sell dualband phones with lowest prices, because they "think" that it cant be unlocked for another carries. So, as peoples search for prices first, they buy dualband cells from Vivo and comes to unlock to another carries. Have here a WX290 from Vivo (850/1900 Mhz):
version: 666
provider: M290A-DATLBR1
customization: CP66GM1D
customization: XP66GM1D
Phone is unlocked but, ofcourse, no signal in other carries:
So, id flashed phone with file "M290X-DAAVBR1-666_XP66GK19_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V40_F5_2010-04-23_En_Nl_Fr_Es_Pt.B0M", removing signal filter and making jumper (same as Nokia 1616). Now, phone fully working in 900/1800 Mhz operators (Claro, TIM and OI).
Regards.
Cryspim
The Following User Says Thank You to Cryspim For This Useful Post:
Old 07-02-2011, 15:37   #9 (permalink)
YellowBoss's Avatar
Member: 1043909
Could you, please, attach here a photo of required hardware modifications.
Thank you !
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 12 09-02-2012 19:17
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.30947 seconds with 11 queries
