09-09-2010, 02:35 | #1 (permalink) |
Junior Member Join Date: Aug 2010 Location: Tecamac Edo. de mexico Age: 36
Member: 1359030 Status: Offline Thanks Meter: 5 | WX290 DEATH in Unlock Is there any Firmware. with which you can flash? They are greatly appreciated. Besos. |
The Following User Says Thank You to Yatzareth For This Useful Post: |
09-09-2010, 10:37 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, I don't think that this phone can be dead during unlock with Infinity-Box. What you have tried to do exactly ? What software you have used ? Post here operation log. As about firmware: you can download it from Infinity-Box support area. |
09-09-2010, 17:02 | #3 (permalink) |
Member: 1359030 Status: Offline Thanks Meter: 5 | Hi, thanks for your answer. I commented that the phone stays in the boot image. and freezes there. Unfortunately, I have no log of operation, and support infinity. not released any firmware. I could flash with some other tool? I have several for Motorola but not where to begin. Thanks for any input..Besos |
09-09-2010, 17:18 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, M290A-2AAVDO1-665_XP66GR1C_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V40_F5_2010-04-14_En_Nl_Fr_Es_Pt.B0M.bin file will be uploaded in "server1" support area in 1 hour. |
09-09-2010, 17:44 | #5 (permalink) |
Member: 1359030 Status: Offline Thanks Meter: 5 | Hello. Thank you for your attention to my problem. download 2 times the file and I get this error. that could be? Sorry for my insistence. But I went crazy. or am marking something wrong? ... Besos |
09-09-2010, 19:02 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, it may be that you downloaded file when it was not uploaded completely. Please, download file once again now. |
09-09-2010, 20:19 | #7 (permalink) |
Member: 1359030 Status: Offline Thanks Meter: 5 | Thank you very much. While you're cute. thanks for your help. download the firmware for the third time. it appears that the first two. were downloaded wrong with defects. Here is the log of the process, but I finally lit the phone. COM8 [VCP0] selected modulo v3.58 Servicio: Motorola-WX290 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: repair security area ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA4C:A00C status: 01 Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash EC240200000000:2BEA0000000000 Flash Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 460800 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.75 2F7B51.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN_331B13D4].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 752F7B51 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN project-id: MAUI.08A.W08.36.SP1.V40.F5, D4131B33 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification Version: 665 provider: M290A-2AAVDO1 Personalización CP66GR1C Personalización XP66GR1C TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected Personalización CP66GR1C customization name adjusted Personalización CP66GR1C customization name adjusted customization detected: CP66GR1C Personalización CP66GR1C Flash EC240200000000:2BEA0000000000 Flash EC240200000000:2BEA0000000000 Escribir security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Listo Flash EC240200000000:2BEA0000000000 Flash EC240200000000:2BEA0000000000 Escribir security area (sec info, hash) security area (sec info, hash) calculation done Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Imei original: FFFFFFFFFFFFFF Flash EC240200000000:2BEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash EC240200000000:2BEA0000000000 Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\Motor ola-WX290_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V40_F5__system_log_752F7B51_331B13D4_2010 0909-123309.B0X.bin Finalizado, tiempo usado: 2 min 37 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Muchas gracias GRAN JEFE AMARILLO! eres muy lindo, gracias por tu ayuda desde Mexico. Besos In the future, Telcel will be the firmware on the stand? |
09-09-2010, 20:39 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, We will try to add more flash files in support area as soon as possible. |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
09-10-2010, 05:53 | #11 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 410795 Status: Offline Thanks Meter: 31 | i tried everythink, i repair imei and make unlock procedure again, format ffs and all but my fone just in motorola logo and off ! YellowBoss i have full flash backup could u process it to get fone back on? thankz |
09-10-2010, 10:50 | #12 (permalink) | |
As about your flash backup: is it a backup from phone before any operations or already after some operations ? | |
09-10-2010, 14:23 | #13 (permalink) |
Member: 410795 Status: Offline Thanks Meter: 31 | thankz i solve my problem! looks like the file on support area was corrupt and somebody upload ir again cuz the first time i downloaded it says buffer error when load in firmware windows, i download it again now and was able to flash , now i revived it and read codes with another tool, thankz! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
