12-17-2010, 22:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 364992 Status: Offline Thanks Meter: 28 | wx290 new version, after unlock no bluetooth i need to solve this urgently |
12-19-2010, 16:26 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Are you sure that before unlock it was no problems with bluetooth ? Did you tested phone before unlock ? Also, post here operation log for unlock process. |
12-20-2010, 18:30 | #5 (permalink) | |
How are you ? Please, tell me more about this problem, f.e. tell, me what is that "two versions" and also give me an answer for my previous question. Brother ! Please, please, DO NOT ignore my request to post here operation log, in other case all my efforts can not helps | |
12-20-2010, 20:07 | #6 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | COM3 [VCP0] selected module v3.70 Device: Motorola-WX290 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B12A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.AE 47CDC0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN_C88F339E].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: AE47CDC0 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN project-id: MAUI.08A.W08.36.SP1.V40.F5, 9E338FC8 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 666 provider: M290A-DAPSAR1 customization: CP66GC15 customization: XP66GC15 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP66GC15 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Motor ola-WX290_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V40_F5__system_log_AE47CDC0_C88F339E_2010 1220-124308.B0X.bin Finished, time used: 3 min 13 sec Remove/Install battery now ! |
12-21-2010, 11:41 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much ! Please, tell me more about this problem, f.e. tell, me what is that "two versions" and also give me an answer for my previous question (please, see your own previous posts and see my previous posts). |
12-21-2010, 20:08 | #8 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | Hello, because i have in my hand two wx290, with one of them i made fullflash with two fijrmware from support from personal argentina and bluetooth works perfect, and then with the other wx290 same operation and result is no bluettooth. tried to read aprom from working phone and flash to bad phone and dead.. i cant find a solution. |
12-21-2010, 20:26 | #9 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | this is the new version, i read it from other phone new version. ==================== New firmware found (v.3.70, database date: 30.11.2010): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software |
12-21-2010, 22:03 | #10 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | here is read flashfile, when i try to put this read flashfile to bluetooth phone problem not power on. Download Motorola-WX290_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V40_F5__fullflash_part_1_of_1_20101221-172851.B0M.bin from Sendspace.com - send big files the easy way |
12-22-2010, 15:22 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, next time follow the instruction and upload files to rapidshare.com or to 4shared.com It's really important to upload files to good servers due to we are really tired to fight with trojans/viruses and other harmful software. We will check your file and upload updated files/software in support area. |
12-22-2010, 15:55 | #12 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | sorry i havent got account in rapidshare and 4shared i will register, thanks. In how many time could you upload repair files in support? because i need to talk my customer and tell him wait for the phones. |
12-23-2010, 15:32 | #14 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | i flashed the phone with the lastest firmware but cant power on.. do nothing when press power button. no motorola logo, nothing.. what can i do i need to repair bluetooth problem. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
