06-02-2018, 21:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | X-Bo x9 Firmware? I've tried this firmwares SONY X-BO X9_MT6580_(by_firmwarelink.com) Code: https://romtaken.com/download-sony-x-bo-x9-mt6580-firmware Code: https://www.needrom.com/wp-content/uploads/2017/02/X-BO-X9-02.zip Code: https://firmwarefile.com/xbo-x9 Code: Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 46 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642029A90EE32F43B1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
10-20-2018, 20:33 | #2 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2278545 Status: Offline Thanks Meter: 0 | I join the problem. I also need firmware on the above phone. After the firmware SONY X-BO X9_MT6580, the phone has become a brick. Preloader is not suitable. Please give a link to the firmware or preloader. Last edited by ivaleks; 10-20-2018 at 20:41. |
10-23-2018, 21:05 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
10-24-2018, 01:25 | #4 (permalink) | |
Member: 150844 Status: Offline Thanks Meter: 309 | Quote:
Code: http://gsmworldbd.com/sony-xbo-x9-stock-firmware-rom-flash-file/ | |
The Following User Says Thank You to bananin For This Useful Post: |
05-27-2021, 22:11 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | needrom.com site looks like cheaters, they block paid accounts and set speed limit. Be careful, you may get loss! DO NOT buy from needrom.com |
