12-05-2006, 10:53 | #16 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | |
12-07-2006, 14:57 | #17 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Calicut Kerala India Age: 46
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | DEAR SIR, sir i cant flash because set that time on pls see below Write: Firmware Write: Flex Write: Language Pack Device: X100 Checking data, wait... Connect... Press and Hold Power button... unlok time COM1 selected Device must be POWERED-ON ! Connecting, wait... Device connected. Working... Current Imei: 354144009657261 SW Version: 1207aJ25_G66 Err: Reset User Code what i can do sir pls help |
12-08-2006, 16:26 | #19 (permalink) |
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | Dear sir , i conect above type conection in mobile conector but no response, no defrense,same condition what happend sir help pls |
12-12-2006, 07:01 | #21 (permalink) |
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | Dear Sir, Your Cable Onle 3 Conection , One Ground And Tx, Rx, Thats Why I Connected That Short Inside The Bord, But No Hope, Any Other Sujections?0 Pls Help |
12-12-2006, 07:25 | #22 (permalink) |
12-12-2006, 09:31 | #23 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, open cable connector again and check that in cable PIN 1 connected PIN 6 ! If pin 1 not connected to pin 6, please, connect pin 1 to pin 6 and repeat flash process. |
12-12-2006, 16:16 | #24 (permalink) |
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | my dear sir u are grate, i flased x100 at ur methed, verry thanks sir, verry verry thanks, but complaint is saim , sim inserted time display is not working, i used file version is 12o7, another problem is canot unlock, we can see Device connected. Working... Current Imei: 354144009657261 SW Version: 1207aJ25_G66 Err: Reset User Code pls give a segection thanks |
12-13-2006, 06:12 | #26 (permalink) |
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | yes,sir grate perfomense sir, thanks sir lot off thanks, infinity support is grate, ilike it good, allthe best, thanku, |
Samsung Jet S800 Unlock problem | javakiller | Z3X-Team Products | 8 | 05-15-2010 12:14 |
x100 unlock problem | PETERB | Infinity-Box | 3 | 01-18-2009 14:52 |
unlock problem eb-x100 | RED PHOENIX | Infinity-Box | 1 | 06-10-2007 08:41 |
problem with x100 unlocking | taoufik.om | PolarBox 3 | 1 | 12-29-2006 12:15 |
pana x100 sec unlock problem | QADRI MOBILE | Infinity-Box | 3 | 02-11-2006 15:08 |
