X2i 3G not working fine see inside error drivers installed correct. downloaded new from support. but see below http://i1372.photobucket.com/albums/...pscc56pzio.jpg |
Hello, First manually update driver to SCI USB2Serial (SciU2S), from C:\InfinityBox\CM2SPD\Drivers. And while connecting phone press both volume keys till booting is done. Br. Infinity Box Support Team. |
use correct boot button use correct boot button, vol up, or vol down |
then uninstall cm2spd full and reinstall it again with new drivers. install drivers auto. connect device and install manually located as you said before. but still same... other box are doing fine and connect device showing info fine.... only cm2spd is giving this error....... |
Hello, Use normal USB cable (instead of magic/boot cable) press and hold VOL+ & VOL- , connect phone with USB(battery should be charged) http://forum.gsmhosting.com/vbb/11612130-post6745.html post result/logs.... |
