Old 03-01-2016, 14:28   #1 (permalink)
Muhammadsaqib11's Avatar
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 360
X2i 3G not working fine see inside error
drivers installed correct. downloaded new from support.
but see below
Old 03-01-2016, 14:41   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
First manually update driver to SCI USB2Serial (SciU2S), from C:\InfinityBox\CM2SPD\Drivers. And while connecting phone press both volume keys till booting is done.
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-01-2016, 15:41   #3 (permalink)
Member: 1892312
Sonork: 100.1651296
Thanks Meter: 76
use correct boot button
use correct boot button,
vol up,
or
vol down
Old 03-01-2016, 15:45   #4 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 360
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
uninstall driver from device manager.
then uninstall cm2spd full and reinstall it again with new drivers.
install drivers auto.
connect device and install manually located as you said before.
but still same...
other box are doing fine and connect device showing info fine....
only cm2spd is giving this error.......
Old 03-01-2016, 16:25   #5 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
Use normal USB cable (instead of magic/boot cable)
press and hold VOL+ & VOL- , connect phone with USB(battery should be charged)
http://forum.gsmhosting.com/vbb/11612130-post6745.html
post result/logs....
Page generated in 0.12911 seconds with 9 queries
