Old 01-12-2006, 04:01   #1 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
X300: [Err: Imei not found or damaged!!!!]
To @InfinitySupport!
I received one piece X300 with imei problem.I 've tried to reflash with few flash/flex/map then repair imei with no luck(in some newest firmware version software says changing imei done but really doesn't) .
Here is the log:
COM6 selected
Device: X300
Checking data, wait...
Action: IMEI repair
Boot...
Press Power button now !
Connecting, wait...
Boot Done
Parameters...
Parameters Done
Check Boot block...
Check Boot block Done
Check space...
Check space Done
Check Flash-1...
FLASH[410702]: 98:0074
Check Flash-1 Done
Check Flash-2...
Check Flash-2 Done
Check Flash-3...
Check Flash-3 Fail
Finished
Remove/Install battery now !
Time used: 29 sec
Now phone has problem with registering network.When I try to select any network band,I always get error message"NOT DONE".And Imei number is always 350421030000600(not the same with its imei stamp).
So I guess I must have a good eeprom file to repair this one.Am I right?
If yes,where can I get this good eeprom file?
If no,do you have any solution for me?
Thanks in advance and hope will get your answer a.s.a.p.
B/r
Old 01-12-2006, 06:49   #2 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
Now phone can access network again but still keep on waitting your idea about changing imei.
Thanks in advance
B/r
Old 01-12-2006, 09:56   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,388
Do you know this phone history ?
Is it possible that this phone was damaged and original flash chip was changed with new one ?
Old 01-12-2006, 16:46   #4 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
Hi again!
I'm so sure phone hardware is 100% in state of original.
Second,customer(he is a mobile repairer also) had flashed this phone with UFO tool(not so sure coz that's all of the information I've got from him ;-) )
Anyways,now this phone was returned to his customer and I have received my money for repairing network problem:-)
And I hope it can't be changing Imei coz it has hardware problem.
Thanks for your customer care and just keep it up!
B/r
Bootkey was not found or invalid. always Error powerplay83 DreamBox 7 02-17-2009 18:31
CRYPTO-BOX not found or contains not valid data Dayratel NSPRO 2 05-11-2006 14:09
Repairing redbox with key not found or sn error ::.::HITGSM::.:: Redbox 1 10-31-2005 07:27
Page generated in 0.27727 seconds with 8 queries
