Old 08-03-2005, 01:12   #1 (permalink)
marmouta's Avatar
Member: 122158
Sonork: 100.1579859
Thanks Meter: 116
Philips 568 unlocked locked unlocked locked
Hi
i have a problem with philips 568 which when i unlock it and after i remove battery the phone become locked.
Old 08-03-2005, 17:26   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
Interesting situation...
Please, read flash from this phone (when it become locked back) and send to:
InfinityHelp at yahoo.com.hk
Also, pls, attach to your mail Log file from Philips software.
Old 08-03-2005, 17:47   #3 (permalink)
Viking's Avatar
Member: 19585
Thanks Meter: 19
Chek your system, hardware, cable...... Soft work for unlock 10000%, I tested on many phones.
Old 08-03-2005, 20:40   #4 (permalink)
Member: 47236
Thanks Meter: 58
i have the same problem with such phone
when battery goes empty phone locked again
Old 08-03-2005, 20:57   #5 (permalink)
Member: 130995
Hello,
Did you tried to flash phone with firmware from support area and then make unlock again ?
Old 08-09-2005, 21:43   #6 (permalink)
galaxi's Avatar
Member: 5915
Thanks Meter: 7
i have same problem with all pieces i unlocked what solution for this problem please ??
i have flashed it with firmware from support area but not have frensh lang
Old 08-09-2005, 23:18   #7 (permalink)
Member: 130995
Hello,
Pls, attach to your mail Log file from Philips software.
As about French language: pls, write here language names that you can see in phone after flashing the next flash files:
P568_041_LP1-L11.04_De_Fr_Nd
P568_041_Main
P568_041_Map_AxF.SAx-M9.M08.04
Old 08-11-2005, 08:27   #8 (permalink)
shurubelul's Avatar
Member: 124026
Thanks Meter: 27
me too i have that problem...phone stop's and after power on...insert valid SIM...i'll try to read the flash and send to infinityhelp, but...
Old 08-11-2005, 10:52   #9 (permalink)
Member: 130995
Hi,
Receiving your mail now. Will check it and inform about results ASAP.
Old 08-11-2005, 11:39   #10 (permalink)
shurubelul's Avatar
Member: 124026
Thanks Meter: 27
Originally Posted by InfinitySupport
Hi,
oki, i'll wait for your response, thank's
Old 08-11-2005, 13:09   #11 (permalink)
Member: 130995
Hi,
Please, flash your phone now with any MAP file from support area. Need to flash only MAP file. "Erase FFS" have to be checked.
After flashing, don't power-on phone (only remove/install battery) and make unlock.
Then pls, test phone.
Waiting for your results.
Old 08-11-2005, 13:17   #12 (permalink)
shurubelul's Avatar
Member: 124026
Thanks Meter: 27
thanks for your answer but...i had to give back the phone on my *******r... but until that i flash the phone with
P568_041_Main
P568_041_Map_AxF.SAx-M9.M08.04 (Erase FFS was checked)
i remove battery and after i unlock phone, i hope will work...
Old 08-11-2005, 14:49   #13 (permalink)
Member: 130995
P568_041_Main
Hi,
Ok, let's see what will happen. And we have some time to analyze readed flash more detailed.
Old 08-11-2005, 15:42   #14 (permalink)
shurubelul's Avatar
Member: 124026
Thanks Meter: 27
Hi,
bad luck... my customer told me that after 3 hours he turn off the phone change simcard with another and...insert valid sim...
Old 08-11-2005, 15:53   #15 (permalink)
OvidelGSM's Avatar
Member: 103544
Sonork: 100.75677
Thanks Meter: 155
looooool ....i think this is fake from infinity Team .... shame !!!!!
Philips 568 Unlock & Imei Change !!! UFoTeaM UfoTools 18 09-28-2007 18:51
problems to unlock philip 568 MrNokia Infinity-Box 4 05-26-2005 17:44
philips 568 unlock update in infinity box mas comm Philips 0 05-13-2005 07:53
unlock philips 568 osya Philips 1 05-12-2005 10:35
Page generated in 0.32153 seconds with 9 queries
