04-12-2005, 17:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | "x300 problem" just bought this product,tried to unlock a x300 but nothing!!heres what i did, installed the drivers,soft, chose x300 ,left the toggle switch on,left the front toggle switch up,used the provided leads(the ones with the jack)chose the correct port settings,(i think)whatever it was showing in divice manager,it was 17, i then chose 1,then 2 but no commiunication!! please help,dont know what else to do, br farry |
04-12-2005, 18:02 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello ! 1. I think that COM-Port COM-17 was correct. Check it again, please. Here is attached picture of "Port" section in DeviceManager. Correct port (on my picture) is COM5 (Infinity USB serial port). 2. You have to use for X300 cable with "G50" label. It's cable with Hands-Free jack with 4 (four) metal pins (pls, see attached picture too). 3. Insert cable into left RJ-45 connector (near Rx/Tx LEDs). 4. F-BUS/M-BUS switch on front side have to be in up position (F-BUS) 5. When you select correct COM port, start software and press "Unlock" button, you have to see GREEN LED is blinking very fast. This means that COM port selected Ok. 6. Now press phone Power button (Red button) for several seconds. When progress-bar start to move you can releas Power button. B.R. InfinitySupport Quote:
04-12-2005, 18:12 | #3 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | hi there the divice manager is almost same but one thing which was differentwhen installing the usb driver it was saying sphere usb not infinity!!how is that possible? please help,i think that we r getting somewhere!! br farry |
04-12-2005, 18:18 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hm... Interesting Anyway, try to make this: select COM port with text "USB" near it, run software and press "Unlock" button. If you will see that GREEN LED blinkig very fast - this means you have selected COM port Ok. Do you see green led blinking ? B.R. InfinitySupport |
04-12-2005, 18:24 | #5 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | hi yes at one stage,i did see a green light blinks fast,i will check my steps and your tips, and will post results,thns for the fast reply, i will double check in device manager to see infinity usb!!. br farry |
04-13-2005, 09:46 | #6 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | hi infinitysupport problem solved,after charging the batterrie for few more minutes,it unlocked the phone ,in 42 seconds!!,supper tool,thnx for the help though, br farry ps,lets hope u bring x70 solution!!!,just kidding!! |
04-13-2005, 10:36 | #7 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Thanks to you too for good words ! We hope you will be satisfied with our product in future too. B.R. InfinitySupport | |
04-16-2005, 20:59 | #9 (permalink) | |
Our main idea: "Even small real work is more important than big future promises" (c) Infinity-Box 2005 B.R. InfinitySupport | |
04-18-2005, 13:55 | #12 (permalink) |
Product Supporter Join Date: Mar 2005 Age: 44
Member: 128745 Status: Offline Thanks Meter: 16,936 | @ needi try not to insert connector completly inside the phone , leave a little space , dont press it hard Best Regards Infinity-Box Team |
The Following User Says Thank You to Infinity-Box For This Useful Post: |
"X300 Phone lock Code" PLZ HELP | meisam | JAF Xtras | 10 | 05-18-2007 22:38 |
Mw30260 display "Parameter problem"??? | colin42100 | Infineon C16X M51 & ARM7 M52 BASED | 15 | 07-14-2004 18:51 |
"ufs dct3 problem" | farry | UFS2 + UFS3-Tornadoflasher | 3 | 02-02-2004 18:41 |
a200 "lcd problem" | Moosani | Samsung Hardware Repair | 0 | 04-06-2003 00:00 |
"another sl45 problem" | farry | x1x to x45/x50 | 6 | 08-16-2002 08:56 |
